Harro,
I have a split dump dump from 999 Automotive I want to sell, reason being it's about 1cm shorter than the stock one which causes my down pipe to touch the underside of my car. Having OCD, I don't like that so I've installed the stock one back again.
Same one as this, purchased from the same store. I have receipt which is included in the sale.
http://www.ebay.com.au/itm/KLS-EXHAUST-TURBO-twin-entry-DUMP-PIPE-NISSAN-SKYLINE-RB20-RB25-R32-R33-R34-/330890072292?pt=AU_Car_Parts_Accessories&hash=item4d0a95d0e4&_uhb=1
However, I've enlarged the holes to fit, removed the stupid divider (was hitting my wastegate flap).
So what you get is something that will fit straight up with out any mods, includes:
* Dump
* A bunch of bolts and washers
* No gaskets
* No divider piece (I chucked it out, on testing with an air compresser it hits that thing)
Save yourself some coin.
$50
Pickup from Canley Vale, NSW, 2166
Reply here or PM
Here are some photos...
I had to work this ling long piece of shit product to fit.
  • Hole have been enlarged
  • Casting marks smooth out with a flap disc
  • Divider removed
  • Proper fitting bolts purchased (nuts/studs provide did not fit)
Oh yeah, free working factory O2 sensor!
$T2eC16hHJIcFHOBy7VepBSeNsI5sBw~~60_58.J
$(KGrHqVHJBMFJipNVsodBSeNupU3bw~~60_58.J
$T2eC16ZHJH8FHQqI,,h,BSeNwdl1Hg~~60_58.J
I had the same thing, my down pipe from them was about 2 to 3 inches short, I had to cut in and weld in a section to lengthen it, had no choice. Good luck with the sale mate
or use a spacer/flange to make it longer...
I'm going v band next so no need for this ling long bullshit lol
Free for me?
for a slab of blonde and I ain't fitting it... I don't want to snap dump bolts (always happens) lol
Just playin. Ain't no body got time for ling long shit!
hahahah that's right!
Unless you're not anal like me, I hate shit that doesn't fit.. gets on my nerves
  • Like 1
  • 3 weeks later...
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
    • Was that also a typo? $350?! Just typing "BMW oil level sensor" and prices start out a lot more sanely than $350. I'm guessing it's a sensor used in one low volume model only or something?
    • They kept the product number the same, so we "didn't pick it up when packing your order". If you packed the order, you clearly saw the box wasn't Hella...
    • Actually, the equivalent skyline part is both cheaper and simpler, maybe you should come back from the dark side?
