Hey guys,
I'm new to the skyline scene. Bought myself a R33 GTS-T not long ago. It's currently completely stock.
I have decided to slightly modify it. However, I'm not willing to spend ridiculous amounts of money on it. I'm basically in need of help as to what mods are the best value for money.
I currently have these in mind:
- CAI
- FMI
- Full exhaust system
- Tune
Please recommend any places in Sydney as well as what you think. Thanks!
https://www.sau.com.au/forums/topic/434174-r33-gts-t-modifications/
Modifying a skyline and not spending what some would call ridiculous money dont work in the same sentence.
You do realise to tune, you require an aftermarket ecu a chip or piggy back atleast. Bring on the money to he spent.
Fmic
Nistune
Full exhaust
Drive...
Then do maintenance
There is $2k
Im new to the 33 aswell and mine has a full xforce exhaust 3.5 inch and theres a receipt for $860 supply and fitted. The one thing i would say is that dont go for a center muffler type but go for the resonator style on any exhaust for exhaust height clearance.
I had a xforce ( http://www.xforce.com.au/products.php?make=Nissan&model=3) with the oval resonator and excluding cat installed after I was rear ended last year. If I recall it was $900. Doesn't sound too bad just recently replaced stock cat with a steel high flow venom 4.25" cat and it sounds pretty good with it. (Due to over fueling it is now popping flames though). If your going to upgrade the zaust wouldn't hurt replacing your down pipe as well (if still stock) for better air flow.
I would recommend being very patient and compiling a list of mods you want to do. Then research them to death before spending. Worst thing you can do is rush into buying things and have to spend money on the same thing twice. Have a look through the for sale section and maybe pick up some 2nd hand bits. That way if for example you buy an exhaust and you decide its too loud/ too quiet for your taste you can simply sell it for (in theory) the same price you bought it for.
Have a look through the forums. This question has been asked and answered many times. Have a serious think about your goals for the car and go shopping!
PS don't be too cheap with your mods. Do it once and do it right!
Edited by mark33gtst
  • Like 3
Thanks mate. Definitely going to try and build my knowledge base from here!
Theres alot to learn from these forums... ill give you advice from my personal experience. Just spent $5k on my car and the bottom end popped a few hours later. Don't make this mistake - make sure you thoroughly check the engine's health before you start modding up anything :)
First thing to do:
timing belt, water pump
Reason why?
Most imports have had their clock wound back, or clusters have been replaced
Then:
  1. Full exhaust (just get 2nd hand) ~$500
  2. Intercooler of some sort, even a R34 GT-t side mount $100
  3. Hit up Toshi for a socketed stock ECU with a new ROM tuned for AU 98 Octane fuel ~$350
  4. Turbotech MBC 0.8bar ~$30
  5. Fry tyres ~Priceless
First thing to do:
Reason why?
Then:
Everybody loves frying tires :)
This times 1000!!! I spent about 20 grand on mine when I bought it. Thinking back now could of saved a lot of time and MONEY by researching more. I would of saved about 8 grand and over a year of time for a better result.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
