hey guys I have a s2 c34 stag and have most parts off it
doors. 200 per
skirts 150
dash 150 With vents and air bag
bonnet 280
front reo 200
rear reo 80
headlights 250 slightly yellow
Or whole s2 front end 750 ( includes guards bonnet and lights and fog lights centre garnish and rs4s front bar )
manual rear cradle With diff 450 without diff 350..... perfect if you want to fit fatter wheels on
whole manual conversion pedals gear surround everything Inc gear box 1450
rear hatch with rs4s wing 200
rear lights with the white over red Tiny hair line crack in one can barely even see and it doesn't leak 150
clock spring 80
airbag steering wheel 150
2x z32 afm both are real used one 150 BRAND NEW one 250
TURBO KIT + intercooler kit
- Brand new kando t67 with Billet wheel upgrade
- pretty much new steam pipe manifold Used for display
- Brand new Genuine tial 44mm gate with everything
- Stainless tig welded dump pipe
- stainless screamer pipe
- fitting oil drain and oil feed All fitting etc needed to fit
1950
Cooler kit to suit this turbo kit or can be easily be altered for low mount
has a z32 afm in piping no holes cut kit With a good core and tig welded stainless piping
reo does not have to be cut etc
$500 for the kit or $620 with afm
Or 2400 For the lot
this kit made 377rwkw on 23.7 psi on e85 all comes in before 3700 rpm a amazing kit ready to bolt on
must sms or call
0430106414
  • Like 1
forgot to mention also have a full tig welded stainless cat back with centre resi and rear muffler sounds amazing 450
Hi I am interested @ your
"a full tig welded stainless cat back with centre resi and rear muffler"
Could you post some photo please?
By the way where are u locate in?
Thanks
I am after an aircon condenser and TX valve which are located behind the glove box. PM price and delivery please.
Hey guys It's red I still have yhe exhaust and skirts and mirror but no condenser SMS me for photos please
Located in dandenong area
Abe
0430106414
Hmm I'd be interested in exhaust manifold and gate if you broke the kit up ?!
I am interested @ a full tig welded stainless cat back with centre resi and rear muffler
Could you Post to NSW??
its a long item but if you wanna organise fraight im sure I can get it wrapped up in padding of some sort
HI Could you post some photo pls?
And do you know how much for the postage (Newcastle, NSW, 2302)?
thanks a lot!
no rust in the subframe
turbo kit gone passenger mirror bonnet and 1 guard gone
cooler kit now 450
lights 200
tail lights 120
rear hatch 180
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
