Black 1998 40th anniversary R33 Gtst
The good:
Engineered and mod plated for motor, Front mount Inter cooler
Registered and insured with the 3L Motor and Front mount.
MOTOR:
RB25 VVT head on RB30 block with external oil feed for VVT
CP 8.3:1 forged pistons
REV Rods
ARP Head studs
Metal head gasket
N1 Oil pump
Greddy forward facing Intake plenum and throttle body
Malpassi rising rate fuel pressure regulator
Walbro 255L/h fuel pump
Thicker alloy radiator
HKS low mount exhaust manifold
HKS 60mm external waste gate
HKS sdjustable exhaust cam gear
Garrett GT3076R
Custom oil catch can
HKS pod filter
Greddy/Trust Front Mount Intercooler
3.5” dump to cat, 3" there after
2” screamer, I have an attachable muffler for this if you don't want to hurt peoples delicate ear drums
Receipts for the head being refurbished 2 years ago
SUSPENSION:
Adjustable rear camber arms
Adjustable rear traction arms
Adjustable front LCA's
Adjustable caster arms
Front strut brace with brake master stopper
Rear adjustable GTR strut brace
Standard springs and shocks
WHEELS:
Advan AVS model 5
17x10 rear
17x8 front
STEREO:
Jensen DVD player head deck
Pioneer 6x9 in the rear
Pioneer 6" in the front
OTHER:
Regoed until mid August 2014
The front bumper I've never seen on any other r33, its plastic not fibre glass and I think it actually looks a lot better than the standard series 2 bumper
GTR spoiler
Keyless entry and alarm
Excedy Heavy duty clutch
Dynod at 227rwkw on 9psi with the standard 25 ecu, I have the dyno papers along with the Engineers reports
Greddy boost and oil pressure gauges
HKS boost controller
The aircon works great
New gear box 2 years ago
I have all the receipts for everything done to this car and the engineers papers
Can throw in a walbro 460L/h e85 fuel pump for the right price
The bad:
Doesn't run very well, this I assume, would have a lot to do with the RB25 ecu running it
Standard RB25 injectors
I wouldn't recommend trying to drive it home, so bring a car trailer or get it towed
A little bit of rust in the engine bay, easy place to fix though
The paint could do with a detail
Selling because I have my eyes set on something else
Open to offers so go ahead
Will not part out, I do not have the space or the time
Inspections are welcome
Pick up the Warners bay Area
Newcastle NSW
$10,000 ono
obecnie , to naprawde jest stajac coraz bardziej latwy do uzyc ubezpieczenie . duzo wiecej , kiedy ty musiany podróz do biznes biuro i zaczekac wokolo dolaczony tylko do napelnic papierkowa robota . Z poprawiony internet online spójnosc , oni maja okazac sie, by byc mozliwy nabyc twojego plan z najmniej wykonalny klopot , od komfort twojego domu . Nowy elektronicznie autoryzowany plan jest zdecydowanie uszly natychmiast te dni z szacunkiem do
chwilówki po¿yczki
  • 3 weeks later...
  • 4 weeks later...
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
