I'm curious if it's worth swapping the os giken close gear as a performance improvement mod ? Could it help make the car feel more responsive ? Most people talk about it as a upgrade after breaking the gearbox oem. I'm more curious about the performance mod of this close gear set. Who tried it back and forth? what is your thought on how it drive ?
I have one and looks like I busted it on Tuesday.
If its a road car YOU MUST HAVE a decent curve otherwise the car will be a nugget. With a nice flat "torquey" curve, it's a great thing.
I swapped between OS and standard numorios times until OS was smashed beyond repair. With stroker and single turbo, once underway it's awesome. But getting off the line in a hurry can be all or nothing due to long first. I did like it tho, you definately notice the difference.
What did you do after the OS was busted?
Yeah Joey just put the box in last week and all seems good. Will give it proper test this Thursday ( rally sprint). Not sure what to report unless it breaks.
So Piggaz I'm trying a standard gearset cryoed with billet centre plate. If that fails, not sure what I'll do?
I Guess theres no real way to know unless it does break lol, how much power is getting put through this transmission?
what clutch and tyre set up is being used?
thanks
About 600rwhp, semi slicks at the track and a gearbox munching OS Giken R3C triple plate. Which I hope to replace with Nismo copper mix before it takes this box out. Altho I looked at it the other day whilst box was out and after about 40k kms, hundreds of launches and half dozen gearboxes it doesn't look like wearing out any time soon.
good to know, this is approximately the power ill be making and im also using a copper mix... will be very interesting to see how this goes
I was having a think about this lately as my second gearbox is rattling around a bit. I was thinking going shorter diff gears and maybe seeing if I could keep the stock 1-4 gears and going a longer 5th for cruising. Also triple plate clutches or high clamping force singles smash boxes so a nismo or the new organic twin plates seem to be more forgiving.
Maybe an option to consider rather than a close ratio gearbox.
That R3C thing is one hardcore clutch.
The Nismo will an awesome "upgrade" and definitely help with boxes staying together.
so hardcore it left impressions on the input shaft.
I'll get a picture with both plates to show how much flex has been taken out of the system.
That would make 1st crazy short
Yeah but I think the op is wanting response, so I assume he is talking about 2nd to 4th gear more than anything. And it would help keep the -5 on song especially in the tight stuff where you can't grab 1 but would like to.
i could be thinking about this all wrong.. but wouldn't that just shorten all the gears by the same amount and not actually make the gap between gears closer, therefore not making a closer ratio ?
Edited by tricstar
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
