Bride \ Recaro "replica" Seats Carbon , Kevlar Etc
For the guy's asking about this seat
I believe it is the Bride Stradia II Sport Style
Would also like to add there might be a $10-20 price increase on all seat's for newer order's as our $ hit $0.86 USD wtf ?
To the people that have payed already i have forwarded your money to the supplier already so it is all locked in
Hi Longz,
Can I join the GB.
2 pairs of Bride Low max Gias II sport style.
1 pair in Blue (if possible, if not red is fine) and the other pair in Black.
Both with Glitter backing and Graduation fabric.
Does it come with rails of some sort.
PM me with the banking details, $1500?
Pm Sent :
Longz : 4 Pairs Bridge Stradia II Venus , 2 Pairs Stradia 2 Kevlar
ADUBZ : Bride Low Max Gias II - Black, Kevlar Back, Gradation Fabric, Red Stitching
R32GOJIRA : Bride Low Max Maxis III - Kevlar, Red graduation fabric **
YE34OK : Bride cuga's with graduation
RandomGuy : Recaro RSG **
CH0SON : GT3 Seats red
jays r33 GTR : Bride Low Max Gias 2 Black , Graduation Fabric Kevlar **
97 GTR : Bride Cuga
Tom Tucker: Bride Low Max Gias 2 black, standard type, kevlar
d1JitZ: bride cuga carbon black alcantara , bride vorga carbon black alcantara
Blake2234- Bride GIAS 2 low max, Kevlar back, gradation centre, black, red stitching, with logos
R0yalT: Bride Low Max Gias II Sport Style, 1 Set Blue, 1 Set Black Glitter backing and Graduation fabric
97 GTR : Bride Cuga
R0yalT: Bride Low Max Gias II Sport Style, 1 Set Blue, 1 Set Black Glitter backing and Graduation fabric ***
Andrew.Y Bride low Max Gias 2 Sport Style- Carbon, black, red stitching, with logo
alright mate, im in. bride gias 2. with the "bride japan" logo on front and back like we discussed. can this come in black alcantara? im hoping to get exactly like in the pics i sent you? if not then just all black. with CF back.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
