Bottom end assembly.
The bottom end of this engine went together virtually the same as any normal RB26 block. The only real was that the oil squirters had to be grub screwed and blocked off, as the 90mm stroke 12 counterweight crank could not be modified to clear squirters. Basically the hardness of the Nitto crank proved to be too hard to reliably machine/modify, also due to the nature of an intermittent cut while modifying a crankshaft.
At the start of this V3 project, I contacted Nitto and asked them about making a custom crankshaft for me. As it turns out I was very fortunate that they had already made a custom one-of crankshaft that was going to suit my purposes perfectly.
The crank is a Nitto 90mm RB26 stroke crankshaft. Rod journal sizes are Rb26/SR20, so it was exactly what I needed.
I was initially going to go with Nitto I-Beam rods as well, but ran into issues with the 19mm wide bearing on the crankshaft. In short, the radius's off the journals was too large to allow the bearings to run properly. So I switched back to conventional Rb26 17mm wide bearings and H-Beams. Nitto's SR20 rods are apparently good for 700+ hp in an SR20, so they will meet my goals no problems.Rod bolts are ARP2000's.
As the block had the oil squirters removed, I have had some jets milled into the rods to squirt oil from the rod journal to the bottom of the piston. This will aid oil flow to the rod journal a little, and also help with piston cooling. This is a very simple approach that was pioneered in the Porsche 917's, and proved to work well in their 1000hp engines.
The pistons are a custom order from Nitto/JE. 89mm bore with a 4cc dome, and a 28mm compression height. To achieve this pin height it was necessary for JE to run the oil ring over the gudgeon pins. There is a steel support ring under the lower oil ring making the ring assembly possible. The pistons are also notched for high level valve lift.
The two oil supply galleries that would supply oil to the head had been drilled out and threaded to receive a grub screw prior to the cleaning process. These plugs were installed now as the oil supply to the head comes from the spacer plate.
Next, the spacer plate comes into play again. An oil gallery is drilled through the top of the plate, to 10mm deep, and then a 1/6th BSPT thread was tapped into the side of the plate to allow a -4AN fitting to be installed.
The plate also has some custom 35mm long 15mm dowels installed here as well.
Before installing the plate, a Tomei pump was installed along with the cam timing gear. The mail oil gallery was also grub-screwed to seal up the oil supply lines to the main and rod bearings.
Then the spacer plate fitment was re-checked with the dowels installed.
(Truthfully, I trial assembled the engine 5 times... But I had to show off just how good this all looks!)
Edited by GTRNUR
Now you can't see it in the picture above, but under the spacer plate there is a custom made gasket. This gasket seals the coolant and oil returns to the spacer plate.
On top of the spacer plate I use a second gasket, which is designed to seal against a copper head gasket. The two fibrous gaskets function to seal the spacer plate perfectly, and also to take up the thermal expansion variations of the plate. So the plate is essentially floating between two compressible gaskets.
In order to achieve the correct compression with these gaskets, the spacer plate was installed in a jig and surface ground to a specific thickness.
The gasket shown on top of the plate here has been lightly sprayed with a little hylomar, my favourite gasket sealing product.
Moving on... The cylinder head.
For this engine I have used a Tomei Complete head. It is essentially a new factory head fitted with the tomei catalogue. Oversize valves with thin stems, Tomei guides, and moderate porting around the valve seats and exhaust ports. It also has Tomei's buckets, titanium retainers and springs. The cams are step 2 procams, 272 x 10.25mm.
I honestly wanted more of a drag ported head for this engine with 260 x 10mm+ cams, but this was a good compromise. For the money there is a lot of good parts in the package, and to liven it up more it only needs a little more porting work. The quality of the assembly is extremely nice too, as you will agree from the photo's of the combustion chambers.
The addition of the wire O-rings is the only modification I have had done. These O-rings match the receivers in the tops of the sleeves.
The last picture shows the copper gasket deformation that occurs when the head is torqued. As you can see, everything is perfectly centred.
Edited by GTRNUR
Finally the cylinder head is installed.
The top side of the copper head gasket is installed with a smear of 3bond high viscosity sealant, to ensure the top of the gasket is chemically sealed to the head. The bottom side of the copper gasket is sealing against the top plate gasket, and the tops of the cylinder sleeves (and the o-ring area).
This engine uses ARP2000 head studs, torqued to 125ft-lb. If the block were fitted with 12x1.75mm inserts, an off the shelf option exists to use ARP CA625 studs which torque to 160ft-lb. For the sake of this build that would be overkill.
That's all for tonight.
Ahhh wow!
Do the fibrous gaskets below and above the spacer plate have any sort of fatigue life due to the expansion taking place, or are they good for the life of the head gasket?
i think I've just jizzed in my pants
Always find this stuff really interesting.
And a kudos to Ian for providing such detail on this system, the thought that's gone into it, etc. I'm no engineer but always good to learn how things work :)
Ahhh wow!
The gasket material has been carefully chosen to be able to seal under a very wide range of operating temperatures. The compressability and recovery combined with the operating temperature capability of the of the material can easily absorb 1.2 thou of variation(the allow plate growth). According to the data sheet, pressure tests performed with nitrogen gas survived pressures of over 80 bar over 250 degrees of operating temperature. It will definitely out live the life of the engine.
I didn't mention it above, but before assembly the alloy spacer plate is surface ground back to a specific thickness. Such that the total thickness of the plate and plate gaskets when installed will seal, and achieve the same height as the top of the sleeves (extended deck).
  • Like 1
Moving on again...
Intake side, cam covers, gears, timing belt, and the ATI balancer all installed.
I went with a Greddy intake on this engine. Not the wisest decision I ever made, as the added size of it meant there was contact with the clutch master cylinder when the engine was installed later. I resolved this issue by lowering the K-frame a little, using an alternate model GTR clutch master cylinder (that had a smaller OD around the piston), and shaving some material off the master cylinder to clearance it. The combination of all three gave me about 9-10mm clearance. I still retain the clutch booster.
What an awesome build. Good to see someone trying something different. Will be a nice torquey engine.
How would the open deck design work on a RB30 with a 3.2 or 3.4 crank..? RB40..?
It would need at least a 10mm spacer plate, as the machining for the larger sleeves/cylinders alters the way the stresses from torqueing the head are applied to the block. If you could get it in a car, I believe you could use a 90x94mm setup. (3589.45cc), so another 240cc on this engine.
Its not something I'll be trying anytime soon though. The whole point of the open deck RB26 though is to allow for easier fitment without having to use adapter plates or chisel away your bonnet framework. If I had used a stock plenum and twin turbo setup, the engine can still pass for stock.
Edited by GTRNUR
And the hot side.
Ceramic coated Full-Race twin scroll manifold, twin Tial gates, and a Precision 6466 with a 1.00 housing.
This has the engine pretty much completed and ready to swap into the car.
  • Like 1
I know I may be getting in a bit early, but do you have any expectations for figures? Obviously the area under the curve is what's going to interest most, but considering the rod ratio, what are you planning on revving it to? Not that you'll have to, to get the most from this setup.
My guess is the whole point will be that it doesn't have to rev or work that hard to make very solid torque and power figures.
I think he said earlier the Nitto SR20 rods were good for 700hp, in an SR, so I'd be thinking expect a bit more on that quite easily.
I love the idea of an engine package that's capable of big power but running it at 70-80% of its capability and still having more than enough on tap without stressing anything.
The valve train is good for 9k. The piston size, rod and stroke combination is the same as the SR23 stroker kits, and they rev those to 10k.
Realistically it shouldn't need to go past 8k, and this cam setup should make peak torque around 6500. The rod bolts are the limitation for revs, not the rod ratio (piston acceleration etc).
Dan is totally getting the idea. Its seems that many people tune RB26's to within an inch of destruction when going after big power. My thoughts are why not have a setup that can produce a good strong result a whole lot easier. Make the power goal you want and do it easily and with a soft tune.
Based on calculations this setup should make over 500kw atw at about 25lb boost.
  • Like 2
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
