shed clearout of a few things...located in northside Brisbane, can post at buyer's cost. All parts for R33 gtst
set of front lower control arms with Hardrace rubber bushes. Bushes have done exactly 3,398k's (as per my logbook photos) and are in as-new condition. Only reason for sale is I have done every other bush on car with Superpro, so decided to fit superpro lca bushes too (didn't notice any difference btween these and superpro). No ball joints but happy to buy new ball joints and press in for you if you pay the cost of them. After $120 for the set (think the hardrace bushes alone cost $109?)
post-78602-0-20368500-1384650354_thumb.jpgpost-78602-0-54989600-1384650399_thumb.jpgpost-78602-0-33077800-1384650418_thumb.jpgpost-78602-0-50259900-1384650433_thumb.jpg
brand-new HEL/GK Tech brake lines. Rears only sorry, used the front ones when doing their brake upgrade. $35.
set of front and rear stock springs. What can I say, they're stock springs, nothing wrong with them. Pictured in top left corner.
$30 or alcohol trades accepted.
Rear RS-R springs on tokico Potenza coilovers. Paint's a bit chipped/aged on the springs but otherwise no signs of any issues, shocks are fine, no leaks, dents, damage etc.
$60 the set, or could split if needed.
Edited by hardsteppa
https://www.sau.com.au/forums/topic/435103-r33-gtst-suspensionbrake-sale/
also have set of front King low springs for r33 gtst with 1xPotenza and 1xKYB shocks. Springs all good just some paint scrapes, shocks all good no leaks dents etc. $40 for springs, $30 for shocks, or both for $60
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
