Are you on Win 8.1? Is it a legit version?
I've found that issue has started since I upgraded. I use Chrome and I can't paste into windows where I otherwise would have been able to. I think it's cause I haven't yet activate my Win 8 license.
Win 8.1 and IE11 is shite - also unstable in that windows in internet explorer freeze as well as not allowing copy/paste functions.
You cant actually uninstall IE11 you have to turn it off in Wndows features on/off.
Again it's control Panel, uninstall programmes and the Turn off windows features by unticking the IE11 box.
I am about to try install IE10 or 9
So had to do a rebuild to revert to Win8 and IE10 :verymad:
Turned off automatic update for explorer and tagged critical updates only during the rebuild
and now copy/paste works again and I can also insert links again :cheers:
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
