http://www.skylinesaustralia.com/forums/sh...ead.php?t=43555
I have said it many times before...do not even contemplate taking your GTR onto the track if it doesn't have a proper baffle in it. People in this thread have punched a hole in their blocks or spun bearings.
It is not a very expensive thing to do but will save your engine. If you want to do a track day in your GTR, please do up your sump first. Oil cooler is necessary, but will not stop your oil from surging.
https://www.sau.com.au/forums/topic/43640-gtr-owners-read-this/
Yes, The R won't be seeing any real action till it has new sump with baffles, large capacity oil pump, oil cooler, bigger radiator, oil restrictors, enlarged oil return galleries and catch-can. So by about the year 2010 I think I should be ready.
Apparently the engine has to come out to take the sump off. Does anyone know what it is worth to fit baffles??
you forgotten exhaust, dump pipe. new turbos, big FMIC, 6 pots brakes, etc ,etc :D
To baffle your sump i think it costs around 200-300 done by the mechanic i use. You might find someone to do it for cheaper.
My Trust sump set up was cheap, but that's because I'm a dodgy Asian. I did not do the sump myself as I do not have an engine hoist nor do I have an angle grinder and a welder. Alternatively, you can buy a ready made JUN sump (not the parts to baffle the sump) for about 3 times what I paid for the Trust item.
I have said it many times, engine revs or how many laps are not important. How hard you turn is the important factor. QR has 3 right hand turns alone after the main straight, consider how much the oil would have moved to the left. Then think of the starved engine being revved to pull the car through turn 3 and bang you have a hole in your block.
So far, my mechanic has handed out accurate and invaluable advice to me, although it doesn't come cheap, although his advice regarding the sump was:
"Some people have gotten away without a sump for a couple of track days, but it's a $10k risk you are taking. If you're unlucky, your engine will blow by turn 2."
I don't know where people got the impression that GTRs are track ready from factory. They're far from it. They're a road going homologation of a race car, except the N1s or the special edition GTRs.
You have no idea how many times I thought I have prepared my car for the track only to be told this this this needs to be changed first. Not a cheap hobby nor car to choose for the track.
On a side note, Sydneykid has explained why the GTRs experience higher oil temps, i.e. 2 turbos and mainly because the front diff runs through the sump.
Hey rb26dett, who is your mechanic? $200-300 sounds bloody cheap. I NEED to get mine done ASAP and am currently trying to get some pricing.
Thanks
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
