Howdy,
Had this S15 for a couple of years. Car was my daily running around 200rwkw. In April this year the pressure plate exploded, destroying gearbox, bellhousing, starter motor, windscreen and ripped the flange off the back of the motor.
Was pretty upset at the time but took the opportunity to take it off the road and build something cool. Always wanted a rb Silvia, this is my chance, firewall was alreasy bashed from the explosion so it was a sign haha.
This is how it sat before I took it off the road.
Plan is to go a R34 Neo motor, E85 and a precision 6266 twin scroll.
https://www.sau.com.au/forums/topic/436499-rb25-neo-silvia-s15/
Then started the slow process of removing the old motor and all the stuff form the engine bay.
Filled the big holes with epoxy steel, then a metal reinforced filler, then a body filler.
Still needs one more layer of filler and a sand before I get the engine bay painted. Motors going in and out a bit atm so leaving engine bay bare.
Engine Acc. Loom was a major pain in the ass to remove. Had to pull the dash as the previous owner had wired in the alarm and headunit etc... with no thought put into it.
Edited by n_D
Scored a R34 GT-T brake setup for a steal $450 front and rear with hubs, knuckles, calipers, pads and rotors etc...
Got some RDA drilled and slotted rotors, still havent decided on pads. Will wait till car is closer to completion.
Straight swap, hand brake cables pretty much line up like the S15 cables.
Just had to get front hubs drilled out to 14mm. Got a race car builder to do this as I've heard its a major pain in the ass without proper drilling equipment,
Edited by n_D
Found a R32 Cross member to mount the motor.
Seen better days, looks like someone oxyd a bolt out of it. Did not notice it until I got home.
Got it fixed with a new washer tig welded in the existing hole. Then took a wire drill bit, went to town on it and gave it a paint.
I rebuilt the top end with a full Nissan gasket kit, water pump, ARP studs etc..
Replaced timing belt and tensioners etc.. with a Gates Racing Kit, been advised to replace idler pulley bolt as they have snapped from using the tighter racing belt. Replaced the bolt just in case.
Got the head ground and chem cleaned
Just pics of all the goodies going in.
Precision 6266 ball bearing twin scroll 0.84a/r
Bosch 1200cc Injectors
Twin Tial 38mm Gates
Forward facing inlet plenum
Nismo engine and gearbox mounts
Powersteering cooler
Braided ABS-delete brake lines
Superpro Rack Bushes
Sard FPR
Walbro E85 460lph Pump
@Performance Tub Kit, w/catch can, rad overflow and powersteering tanks
Motor is in the car. I need to get either the subframe or brackets cut and shut to move the motor back. Definitely sits nice and low though.
If I can move the motor back about 30mm, I can fit thermofans on the radiator as pullers, use a pusher on the A/C Condensor and keep aircon :)
I did consider slotting cross member but its not possible with the r32 xmember, can be done with the 33. Will be getting subframe modded when i send it off for exhaust and intercooler piping.
Hopefully have the car done march/april next year, fund after new years are low lol.
Bought most of the big expensive stuff, still need a clutch NPC quoted me about $1250 for a single plate organic that will hold 450rwkw with a billet flywheel.
Mate is spraying engine bay for free :) still gotta pay for the tubs to be fitted and the wiring.
Edited by n_D
Its from rc-turbo.com think u can buy through eBay.
Cost me about $1100 with the throttle body. Solid welds, individual runners, flat surfaces etc can't see why it wouldn't perform like any other decent manifold .. couldn't justify money on a plazmaman/Greddy
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
