Manifold is finished, going to be sending off car this week to get motor moved back, tubs fitted, intercooler piping and get exhaust plumbed back.
Fab shop is going to fab up wastegate piping so I can easily swap from plumb backed to an external gate :whistling:
"""""can a mod please delete those blank posts^^^^"""""
Edited by n_D
  • 3 weeks later...
  • 3 weeks later...
Tow trucks booked for tomorrow, will be tripping over it in my garage again :)
Hopefully motor out just once more, slap up paint for the engine bay and start putting everything back in.
Going to be welding and boxing up the rear subframe, while it's out I will replace the pierced fuel tank the previous owner drilled into while mounting an amp lol
Damn ecu and tune is going to cost a fair bit :(
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
