the seat belts in my gf's 94 soarer ****s up sometimes
the drivers one sometimes wont come down so u can put it on and the rear drivers side one doesnt move at all
it was imported and complied in 2001 and shes the first owner
u reckon it could have been done by the same guy??
im not to sure, but it was never imported under the new RAW. So its not one they are looking for. I belive your seat belts would have been changed to Australian ones. Under the new system they leave them as they USED to meet the ADRS.
you really should have these belts checked...sounds like retractor is not positioned & tightened correctly ....remove the rear seat & quarter trims and have a look
bwaahahaha!! DOTARS screwed up on this one. The seatbelts on 91-93 Soarers do not comply with the relevant ADR (even though they are perfectly safe), however some paper pusher at DOTARS accepted these non-complying belts when the workshop (I know of at least one, however this may be the case accross the board) presented their evidence package.
The workshop did everything right and due to DOTARS' screw up, all these cars have had to be recalled. Word of advice to anyone owning these cars: simply decline the request to have complying seat belts fitted. They can't force you to do it and it will only cost you money.
The same thing happened with a bunch of Delicas and their swiveling (not allowed under ADR's) seats and when DOTARS initiated a recall, if the owner of the vehicle did not wish to make the necessary modifications, there was nothing they could do.
This is off my inspection report for the Soarer we just did, it was nothing to do with DOTR's stuffing up the RAWS should of known to check them 1.1 SVE Doc shows belts as being duel sensitive, vehicle fitted with belts marked "V" (not duel sensitive) Should read VW on belt.
Mainly 91 some 92 Soarers, we are fitting aftermarket belts like used under CPA some people will use 1993 factory belts.
And being a safety issue if you refuse to have the recall fixed by RAW you vehicle regerstration will be cancelled.
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
