So you had the Retrofit done?
The reason:
In 1989, the Australian Government restricted the use of refrigerant R12 under the Ozone Protection Act, thus requiring replacement of the use of R12 with the environmentally friendly R134a gas.
R12 to R134a conversion (retro-fitting) for older vehicles conditioned to use the R12 gas, as R12 gas is no longer available to consumers.
Think there is more to it than just changing from R12 to R134a.
Also any shop that is still doing R12 would be putting their livelihood at risk :(
Edit: Had mine retrofitted about 16months back. Going strong and cold
Edited by Sinista32
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158423
Yes it's different stuff though it's called hychill and will more than likely replace 134a , I had the oil changed system evacuated and r134a added lasted one day before over pressure , guys are traders on sau and very good to deal with but my research says maybe too much gas was added or something as 32's are designed for r12 which runs at less head pressure, who did yours? Do you know how much oil and gas was added?
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158586
Hychill will not replace R134a. The only reason it became popular was due to a legislative loophole, which is now being closed.
Meaning, misinformed and unlicensed business/traders were technically able to purchase the gas and consequently service peoples cars.
As an ARC licensed mechanic, my advice would be to take it to a licenced business who knows what they are doing.
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158646
Yes absolutely could be I just worry cause the amount if guesswork with volumes and pressures and if there is a better gas that works at specs posted on the compressor why not look into it? It was actually working very well till the relief valve opened but this other gas is much more efficient and runs less pressure it's used in many older fords and Holden's that are just not suited to 134a anyway I will look into costs as it can be bought locally and see if someone will do it for me otherwise I could but a manifold and DIY
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158647
With the 134 conversion I have spoken to a few shops, some say need new filter and tx valve oil etc some say different hi low switch some say nothing just evacuate and recharge its a bit confusing , at least hychill is seemingly compatable with all systems from what I read
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158653
And I wrote that before your post came up on my phone in case your confused lol I just don't want to go through another compressor, parts cannot be purchased for them so it's second hand or big bucks for a new one if they can still be bought so I was just trying to reduce the workload on the poor old thing but if I can't then I can't
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158659
Yeah that is fair enough, but the thing with air con is that you can't half do it. In for a penny, in for a pound. And you really have to know what you are doing. If you think that's bad, spare a thought for some cool room systems that use 404 gas. Its $300+ per kg.
Edited by White GTS-T
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158668
I did a compressor change on an underground chiller that took over a hundred kilos of r12, most big chillers still use it cos its the shit.
Also fridge gas got a new environmental tax or some such in the last year or so. That's why "$100 regassess" aren't advertised as much anymore, it costs way more in refridgerant.
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158759
The chiller I did was a baby my boss said, at that was only one side of it, it ran parallel compressor ccts. It was cooling water for a swampy that was lucky if it dropped 2deg off ambient air temp, mines have to much money lol. Bit off topic though.
to op change your dryer/receiver and vac out properly and pressure test, then regass while checking your pressures and temps and there shouldn't be any dramas.
Edited by R33shaun
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158768
Well I ended up doing it myself after system was professionally evacuated previously . I got a rig , oil with uv and hychill, I know it is probably not legal and frowned upon but what's the difference with other things we do ourselves ? Anyway it's nice and cool pretty easy to do hopefully it lasts if not the can only cost $21 so worth the risk if it doesn't and I will hard wire fan to come on with a/c button too just to help things along.
Scott
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7169654
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
