So you had the Retrofit done?
The reason:
In 1989, the Australian Government restricted the use of refrigerant R12 under the Ozone Protection Act, thus requiring replacement of the use of R12 with the environmentally friendly R134a gas.
R12 to R134a conversion (retro-fitting) for older vehicles conditioned to use the R12 gas, as R12 gas is no longer available to consumers.
Think there is more to it than just changing from R12 to R134a.
Also any shop that is still doing R12 would be putting their livelihood at risk :(
Edit: Had mine retrofitted about 16months back. Going strong and cold
Edited by Sinista32
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158423
Yes it's different stuff though it's called hychill and will more than likely replace 134a , I had the oil changed system evacuated and r134a added lasted one day before over pressure , guys are traders on sau and very good to deal with but my research says maybe too much gas was added or something as 32's are designed for r12 which runs at less head pressure, who did yours? Do you know how much oil and gas was added?
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158586
Hychill will not replace R134a. The only reason it became popular was due to a legislative loophole, which is now being closed.
Meaning, misinformed and unlicensed business/traders were technically able to purchase the gas and consequently service peoples cars.
As an ARC licensed mechanic, my advice would be to take it to a licenced business who knows what they are doing.
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158646
Yes absolutely could be I just worry cause the amount if guesswork with volumes and pressures and if there is a better gas that works at specs posted on the compressor why not look into it? It was actually working very well till the relief valve opened but this other gas is much more efficient and runs less pressure it's used in many older fords and Holden's that are just not suited to 134a anyway I will look into costs as it can be bought locally and see if someone will do it for me otherwise I could but a manifold and DIY
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158647
With the 134 conversion I have spoken to a few shops, some say need new filter and tx valve oil etc some say different hi low switch some say nothing just evacuate and recharge its a bit confusing , at least hychill is seemingly compatable with all systems from what I read
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158653
And I wrote that before your post came up on my phone in case your confused lol I just don't want to go through another compressor, parts cannot be purchased for them so it's second hand or big bucks for a new one if they can still be bought so I was just trying to reduce the workload on the poor old thing but if I can't then I can't
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158659
Yeah that is fair enough, but the thing with air con is that you can't half do it. In for a penny, in for a pound. And you really have to know what you are doing. If you think that's bad, spare a thought for some cool room systems that use 404 gas. Its $300+ per kg.
Edited by White GTS-T
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158668
I did a compressor change on an underground chiller that took over a hundred kilos of r12, most big chillers still use it cos its the shit.
Also fridge gas got a new environmental tax or some such in the last year or so. That's why "$100 regassess" aren't advertised as much anymore, it costs way more in refridgerant.
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158759
The chiller I did was a baby my boss said, at that was only one side of it, it ran parallel compressor ccts. It was cooling water for a swampy that was lucky if it dropped 2deg off ambient air temp, mines have to much money lol. Bit off topic though.
to op change your dryer/receiver and vac out properly and pressure test, then regass while checking your pressures and temps and there shouldn't be any dramas.
Edited by R33shaun
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7158768
Well I ended up doing it myself after system was professionally evacuated previously . I got a rig , oil with uv and hychill, I know it is probably not legal and frowned upon but what's the difference with other things we do ourselves ? Anyway it's nice and cool pretty easy to do hopefully it lasts if not the can only cost $21 so worth the risk if it doesn't and I will hard wire fan to come on with a/c button too just to help things along.
Scott
https://www.sau.com.au/forums/topic/437021-r12a-gas/#findComment-7169654
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
