Missed out on the cheap price for the SS, stupid Mark not getting all his personal administration in order, oh well, It will still be awesome x1 million.
Also painted side mirrors satin black to match the roof, why you may ask, because I had some paint and was bored.
Thanks for the links.
The main problem is there is nowhere for the air to exit, most (all) cars have some form of venting built into them, alas the MX5 is designed like a parachute when fitted with a hard top, I will get some MX5 dash vents from the wreckers and install them at the rear of the parcel shelf, I will then duct it out the back and have it exit on the passenger side utilising the little tool bin thingy in the boot.
Im guestimating that it is a low pressure area so air should be sucked out whilst driving.
2 each of these bits, just need a hole saw to suit and some balls to do it.
Installed where I drew the boobies.
After nearly being rear ended whilst sitting at traffic lights I took a idea that my mate did to his car, I fitted a flasher unit to my boot lid brake light.
Hopefully a flashing red light might catch the eye of the next idiot who isn't paying attention when driving.
Fitted Sparco 4 point, fitted fixed seat, fitted fire extinguisher, bled brakes, emptied glove box, checked all fluids and oils and removed floor mats.
Race prep done for Sunday, LOL
After a round at Wakefield the Silver Slug has showed a few failings, the diff is garbage and single pegging, looking at a KAAZ 1.5 to sort this out, the RE002 are not good either so some Semi's will be looked at after the diff is done.
Brakes held up fine so no dramas there.
Very small engine leak discovered, only very minor but I threw in some NULON stop leak to hopefully soften up the gaskets and get them sealing better, then I found out it might be the power steering leaking at a connection which I will attempt to tighten later, the leak only turns up on the track.
Trying to decide if I want to get another motor to rebuild over time or just get the one in it done. nothing overly major, basic bottom end rebuild with better rods, all balanced, head rebuilt and shaved to up compression a bit, some cams and a ECU so everything talks nicely, and not a turbo in sight.
I also want a Ishift for it so I don't have to keep looking at the tacho.
After turboing 3 mx-5's, i wouldn't bother doing anything with the motor except a turbo, the first b6 na went from 58rwkw to 165 with no internal mods, and was thrashed daily for 6 months till it was written off, and the b8's respond even better. How do you find the chassis stiffness, the last one i did we fitted a full butterfly brace, and it seemed stiff as.
I don't have a problem with the stiffness of the chassis.
As for turbo's, been there done that, not interested, yes I know you can make easy power with a turbo but I would have to rebuild it anyway to get some form of reliability.
Owning the 5 is not about making big power, if I wanted big power I would put a turbo on it after a rebuild and make 1??kw or 13BT it and make well over 300kw or a big lazy V8, but if I end up making 90ish KWATW and can daily it and run some super sprints and its reliable for a few years I will be happy.
As for power, a member is making 94ish atwkw in his 5 and doing 1.11's at Wakie, learning to drive it properly and set up will assist me in smoking cars with twice my power around the track, I learnt my lesson with my old Skyline that lots of power = lots of hassles when it comes to reliability and the amount of money spent on consumables like gearbox's, tyres and brakes and everything else that comes from running a motor hot and hard.
Plus I'm only in it for some fun and the only times I want to beat are my own.
But this is what it would look like if won LOTTO >
  • 4 weeks later...
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
