Location: Riverland 2hours from Adelaide - Can arrange inspection in Adelaide if needed
Freight: Will ship at buyers expense
Josh
jbuchecker(AT)hotmail(DOT)com
Ph: 04-three-zero wun-ate-five ate-wun-three
All standard parts taken from my R33 GTR which I sold a few months ago.
Odo showed 80,000km
Turbos $300
Almost zero shaft play, look in excellent condition. Looking at the housing you can see the wheels haven't touched it
ECU $100
Working. Used to get car through inspection
Coilovers $200
I'm not 100% certain what condition they're in but I assume not too bad due to the kms and state of the rest of the car. Was imported with them and were also re-installed to get my car through inspection.
Injectors $200
Once again assumed working fine as were used to get car through inspection
Stock Cam gears $50
Fuel pump $80
Coil Packs $20
Found them listed at $100-$200 but can ONLY FIND 5 of them!!! My mechanic only gave me 5 back and I didn't notice until now. Worked fine at 15psi/265kw@4wheels but broke up at 17psi
Will give away free with any other purchase if someone wants them
Spark Plugs - NGK BCPR7ES $20
Look in good condition, assume they were put in during the 100k service when the car was complied putting them at 5,000-10,00km old. Replaced when coil packs were done.
https://www.sau.com.au/forums/topic/437216-r33-gtr-oemstock-items/
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
