Here are a couple of things I'm selling in a new years bid to be less of a hoarder. Both Items are pick up preferred but can post if uber necessary.
First is a Blitz Turbo Timer I bought a few years ago that has never been installed as the car I bought already had one. $25
And second is a Nismo short shifter that I bought years ago when I was in the 'Pulsar Group of Australia'. Have a feeling its for an N13 or what ever has a similar gearbox. $45
If your interested in either or have any questions send me a PM and we can work things from there :) Thanks for looking!
I don't remember the n13 rims being anything special, can I ask why your looking for them and not another set of holden rims? Would just like to know if i missed something when I was a pulsar owner is all.
Ah fair enough, well for the week or so I've been part of their facebook group I've seen a few 4x100 sets come up so they are around, if your part of the group you'll see anyways what get put up. This little project for track use at all or just a run about?
both mate, daily, with a spare set of wheels on semis for track......
engine will hold a little surprise too.....
can you link facey page mate? i cant find it!
Well I hope to see this little beast on the track at some stage, I want to see what the little surprise is! :P
