Hey guys,
I'm shithouse at Photoshop and wondering if anyone here could help. I'm after an image for my head unit in the car. I did manage to make a basic one but I don't know how to make it wider and fill the whole screen. The image needs to be 2048x1536.
Basically I just want to make a black background with the nismo logo in the middle of the image. The older logo with the solid red o.
Thanks guys
https://www.sau.com.au/forums/topic/437459-nismo-image/
  • 1 month later...
hello guys im having trouble with setting this as an actual wallpaper for the double dim for a Sony XAV-63 i can only view the image, does anyone have any ideas on how to or if its possible at all? cheersF7QtW0C.jpg
Edited by Gdaymate123
https://www.sau.com.au/forums/topic/437459-nismo-image/#findComment-7198515
