All items from my personal GTR 32. Located in Melbourne.
Air conditioner cooling unit - $220
Heating unit assembly - $240
Complete blower motor and fan assembly. Working well. - $150
Transfer case originally from R33 GTR - $220
Rear seat (back and bottom). Excellent condition - $120
Cusco strut tower bars suit R32 Front and rear. Avg condition. Scratches and paint chips - $180 pair
Weather strip retainers (L&R). Poor condition rubber strips, both suit restoring. Metal guides are excellent condition - $40 pair
Rear wiper motor - $90
GTR floor mats. Complete set. Avg condition, usual wear, no holes - $140 set
Interior carpet. Good condition. No stains, no burns. 2 small cuts for harness bolts - $120
Air con compressor, bracket, gas cylinder, and hose - $130
CUSCO springs (from Zero 2E coliovers) Cusco ID65 200 series. Spring rate: 11kg, Inner spring diameter: 65mm, Length: 200mm, Stroke: 100mm. Travelled 2000kms - $120 pair
GTR 32 front grill (silver) Good condition. Centre plastic clip missing - $110
Interior rear side trims (L&R) Excellent condition. All clips in tact, no tears in vinyl - $80 pair
Factory gauges for boost, water temp, battery. Fits into single din slot. Comes with loom plug - $110
Rear seat belts. Excellent condition. Barely used. Belts retracted into spool. Comes with fitting bolts - $100 pair
Climate control head unit. Good condition. All buttons work. Comes with loom plug - $90
Top cowl cover Fits under front wipers. Excellent condition, no damage - $40
Complete heater / AC ducting. Full kit includes behind dash and under carpet ducts - $30 set
Rear window lower outer moulding. No damage - $35
Rubber weather shields (L&R). Heavily worn but still working - $30 pair
Front door outside moulds (L&R). Poor condition. Suit painting - $40 pair
A-pillar trims (L&R) 3 small holes in drivers side for pod gauge fitting - $40 pair
Rear parcel shelf (original). Good condition - $40
Original Nissan brake lines and used Bendix pads - $40
Nissan standard CAM gears - $40
Oil catch can. Never used. Looks about the size of 500ml - $20
Rear seat firewall plate. Avg condition. Some scratches - $35
RB26DETT oil air breathers and joins - $20
Antenna booster - 12V amplified New. Boosts weak FM radio signal (10dB gain). Problem particular to R32's where the antenna is built into the windscreen - $20
Under bonnet trim Avg condition. No damage, just needs a clean - $20
Sun visors (L&R) Avg condition. Need a clean - $25 pair
Boot trim, carpet, and board Good condition. Left side trim torn slightly. Holes cut in side trims for struct tower bar. Selling as set - $25 set
Rear window wiper -$20
Nissan spare jack (original) - $15
Child anchor points and brackets Fitted onto rear parcel shelf during compliance process - $15
Interior roof lining. Excellent condition. No damage - $20
Pics available for all items..
https://www.sau.com.au/forums/topic/437715-random-parts-r32-gtr/
  • 2 months later...
Hi just wondering if you are able to ship the rear windscreen moulding?
If you are referring to the rubber moulds, these are heavily worn. If you are talking about the hard plastic moulds, then yes I can post within Aust.
Allow $15 for postage
  • 3 months later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
