Hi all,
Due to a setup change on my R33 GTR, I have for sale my excellent condition set of Genuine Tein Control Master Type Flex Coilovers, complete with the Tein EDFC (Electronic Damping Force Controller)
These coilovers are top shelf quality and manufactured in Japan, not China, and are suitable for BCNR33 and will also fit BNR34
All 4 are in outstanding condition, and have seen very little use overall - My car came with this setup fitted and in as new condition, and has since covered around 3,000 km's only.
Spring rates are 8kg (F) 7kg ® from memory, and provide a great range of adjustment to make them firm yet comfortable for everyday driving, while also being excellent on the track.
The EDFC gives you the ability to quickly and easily adjust the damper settings on the fly, from inside the cabin.
Technical Information from Tein:
TEIN has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The FLEX damper Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. We have incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The FLEX damper kit includes pillow ball upper mounts, which increase steering response; 16 levels of damping force adjustment, and is compatible with the EDFC (Electronic Damping Force Controller) for added convenience and adjustability.
Standard Features:
• Steel Construction
• Twin Tube internal construction
• Ride Height adjustable via threaded body and spring seats
• 16 way adjustable dampers, compression and rebound combined
• Pillow ball upper mounts for increased steering feel
• Upper camber adjustment on front for strut type vehicles
• Larger piston diameter for strut type front and rear (22mm)
• EDFC (Electronic Damping Force Controller) compatible
• Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
Per the Tein USA Official website, the Control Master Type Flex base kit will set you back around $3000USD, and that does not the EDFC, which will add another $400 or so.
I am asking $980.00 firm for the whole kit - Note this is DIRT cheap, so please don't haggle or try low balling.
Pickup available on the North Shore in Sydney, or alternatively you are welcome to organise your own courier to pick up.
First in, best dressed!
Cheers :)
I have had these coilovers in my car for 6 years and feel exactly the same today as they did back then.
Quality product!
Not at this stage sorry mate, I would prefer to sell the EDFC and suspension as a package.
Price drop to $900.00 FIRM!
As above, and per the photos, they are in excellent condition and were only removed due to a complete change in my setup, so there is no need to rebuild.
This is a high end Japanese coil over package that I'm selling at a dirt cheap price purely to move them, it's a damn good suspension setup for minimal money, so my loss will be someone else's gain here.
Cheers!
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
