Sorry to start a new thread but from what I can find is evey1 elses issues seem to vary...
R33 running
RB30/25 combo, z32 afm, chipped ecu, bosch pump, Twin turbos, Greddy EBC, Built manualised auto box.
So as it goes.. drove car home from gearbox shop (after new box fitment) parked in driveway (car drove beautifully and was pretty much nursed home), came out next morning to check on dash wiring as cluster is not working, not knowing the the fuel pump switch is on the dash, long story short crossed fuel pump wiring as it was dodgy as shit (EEk), found the blown fuse replaced and re-assembled went to start it and the following
really hesitant in starting needs a bit of throttle to coax it into running then idles ok but wants to die every 30secs if not given a squirt on idle, wont boost under load but will rev freely on a single squirt but if pumped to rev up will cough and splutter. Under load wont boost can hold the throttle open 1/10th and seems to go ok but the second it goes down further dies out and feels like its on 2 cylinders but if accelerator pumped under load seems to want to go a little better but don't want to push it to detonation as still coughs and farts!!!
So this resulted in the following
New spitfire coils
New plugs (0.8mm gapped)
replacement (tested ok) ignition module
New z32 afm (and computer reset will stall when afm unplugged)
Pressure reg reading steady @ 45psi
Tried a known good Ecu (worse result and doesn't want to idle at all...)
Replaced CAS
Checked timing hasn't slipped (from top view seems ok, wound the motor over a good 8 times to see that marks lined up (didn't want to pull balancer to get cover off so viewed from top cam marks)
Hooked up Ecu talk software and no faults and read outs seem ok, pic attached of car on idle.
I'm desperate for an answer! About ready for it to go to the shop... Was thinking Racesolutions as im in the Penrith NSW area?
As it seems pump related I would check you are getting full voltage to the pump with car running.
Someone else's dodgy wiring is a nightmare, why is the a fuel pump switch on the dash?
It is running standard in tank pump to push fuel to surge tank in boot,
then a Bosch pump under the bonnet, no idea why it is on a switch I was scratching my head at the same thing (stupid idea! considering it's just spliced into the standard wiring for the pump so remote power/ecu controls the unit switching on via relay as standard).
Regulator gauge reads a constant 45psi if it was a fuel pump voltage issue would I be correct in saying if it was to lean out under load the regulator pressure would drop to show this happening?
I get what your saying in that as the car requires more fuel the pump has to work harder to get it there with the same pressure (hence draws more power). So if it was a voltage issue I would see the gauge drop as it needed more fuel as it wouldn't supply the power. Correct?
Yeah that's true about the pressure, missed that bit, but we are just assuming that's the base pressure its tuned at. As you didn't do it is hard to tell. I would pull off the pressure reg vac line and prime pump, see what the pressure goes to, it should be higher than with engine vac applied. I would still check pump voltage.
Ok, will throw a volt meter on when I get home and post up what it's getting on idle and under load.
I am relatively sure I have ruled out the possibility of a sensor fault and really does feel like it's not getting the fuel it needs.
I have held the fuel return line with a set of pliers and the motor on idle sounds stronger and more full if that makes sense but no difference in the rev range, with the bogging issue still the same, it is as if it's getting fuel as when in gear and the accelerator pressed past that point it wont die but will sit for a bit sounding like its on 2 cyl without stalling until I let off again if I pump the accelerator under load it will rev a little more but will start to pop and miss.
I'm thinking if the wires to the fuel pump crossed and shorted (and the fuse blew) could this still have caused damage to the pump that may only be evident under load??
Voltage is a constant 14.8, no difference when the vacuum line is taken off in regards to pressure reading.
with the car running? The fuel pressure should raise when you disconnect the line with the car ruining.
So that issue sorted, car runs 3 pumps, 1 for nos and 2 for general supply one external one internal. Got that issue sorted and have the 2 pumps running that should. I now get a reading of 20psi but with other switch hits 100psi? Reacts and drops like it should but no fuel pressure with the 2 pumps, getting the voltage it needs? Now revs as it should (bit rich) but will break down on boost and i dont want to push it with such low readings
Edited by Caelen
So car went to MRC at castle hill, got it back all running A1, was rich as hell and miss firing like crazy, got a false reading from fpr due to it only been in use for the NOS, guys did a really good job and car runs beautifully now! The best shop I have been to for guys who know skylines!
Didn't have much time to leave it with them due to working hours and being able to pick it up. They had it a few hours did a safe tune on 10psi @241kw/atw has a bucket load more potential just needs an aftermarket ecu, tried running it on 18psi but cant get the niztune ecu to feed more fuel under high boost even with the software Mark was using just wouldn't let any more through. So no power run on high boost until I work out what to do.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
