Hi guys,
I've searched online for quite a while and haven't found any threads that match my problem so far, so here goes.
I have a problem with my AWD in the 32. It seems that the AWD is kicking in when it isn't needed. When I'm just cruising at 70km/h on constant throttle, the torque meter shows a constant 5% and increases with more throttle (never more than 10% though). This causes the car to stutter ever so slightly while cruising. Basically, the car is always in AWD mode.
A bit of background:
This only began straight after I had the front two tyres switched to brand new ones. The tyres are the same size all around. After having this done, I also had the wheels aligned. My suspicion is that it's to do with the alignment. This problem wasn't there before.
Anyone have any ideas?
Cheers in advance.
https://www.sau.com.au/forums/topic/438047-r32-gtr-awd-problems/
Always the same problem with ATTESSA.
Think about it.
You fitted new front tyres, no mention of new rears so I presume the fronts are now bigger in circumference than the rears?
So for any given road speed, the fronts are rotating more slowly than the rears.
Thus the ATTESSA thinks the rears are slipping and applies torque to the front, trying to compensate.
The ATTESSA computer has a small tyre wear allowance but once you exceed that, it's going to start applying front torque which is why, if you must run uneven circumference tyres (front to back) put the new tyres on the back.
Then the fronts will be rotating faster than the rears, moving the wear allowance envelope in the opposite direction.
Always run a tape around your tyres and note each circumference. Fit the largest on the back.
Unfortunately most tyre shops presume GTR's have a 3rd differential, so they don't consider wear when fitting up partial sets of tyres.
Think about it.
Think about it.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
