Hi
I have for sell a 1993 r32 gts-T which has done 93xxxkilos original mileage(have the papers to prove it).
It’s a 5 speed manual.
Car has never been in an accident and has a very clean body.
No dents or scrathes what so ever.
The asking price is 8500(slightly negotiable) with RWC.
The car will only need the stock bov and airbox to be put on in order to get a rwc,which I will b providing if the buyer wants to buy it without rwc.
Car had a rwc 6months ago(I still have the papers).
The car has no engine leaks or transmission problems.the aircon works but it needs the compressor gas to be refueled.
The car has the following engine modifications done.
1-D2 coilovers(worth 1000aud)
2-full body kit.
3-18inch ENKEI rims.
4-Greddy profec b boost controller.
5-turbo timer.
6-3 inch turbo back exhaust system.(the muffler was taken off to get rwc but I will provide that with the sell as well).
7-WALBRO fuel pump.
8-Greddy oilcatch can.
9-Front mount intercooler.
10-trust shift knob.
11-K&N short ram intake.
12-cusco front strut bar.
13- JVC head unit.
14-Alpine amp and subwoofer.
SERIOUS BUYERS ONLY.
No swaps or trade.
post-86840-0-50993200-1390600770_thumb.jpgpost-86840-0-87725600-1390600785_thumb.jpgpost-86840-0-62293400-1390600803_thumb.jpgpost-86840-0-11045500-1390600838_thumb.jpgpost-86840-0-60656600-1390600850_thumb.jpgpost-86840-0-78692500-1390600865_thumb.jpgpost-86840-0-59401100-1390600904_thumb.jpgpost-86840-0-08392300-1390600894_thumb.jpg
