Nice! Make sure you have a good read through the different topics, heaps of good information! Hahah yer true! I'm yet to go to a track, just sorting out little things with the car first. I'm 19 mate, I think my profile has that Info... I'm located in larrakeyah, which is just near the Darwin CBD.
Are you gonna drive it back up here?
Also what kind of r32? Mods? Etc
https://www.sau.com.au/forums/topic/438134-skylines-nt/#findComment-7181608
Completed the drive! All went well with no issues! Conveniently I arrived in Alice Springs the night before the open speed limits were brought in ;) Was goooooood fun!
I'm having an issue with my car now, when I run the same boost as I was running in Adelaide, it backfires and hesitates, this decreases when I turn down the boost but I want to sort this issue out!
I've narrowed it down with some brain storming to an issue where it's not getting enough fuel, hence running lean. First thing I did then was replaced the fuel filter and it seems to be running better but the issue is still there.
The guy I bought it off couldn't tell me the last time the sparks were replaced so I am yet to do that. I'm thinking maybe injectors are blocked? Won't be back in Darwin till the end of the month so have a few things that I'm ordering for it so I can have a fiddle when I get back :D
I'm Harrison btw haha, 18 and live in Bayview.
Car is a 1993 R32 GTST grey mods include:
RB25 turbo upgrade
440cc Injectors
Greddy 2 stage boost controller
Tein super street coilovers
Unknown aftermarket exhaust
Turbosmart Plumb back BOV
R32 GTR FMIC
HKS POD filter
Adj rear camber arms
Front GTR strut brace
Drifttek 17's
Full R32 GTR front end conversion
And semi slicks on the back (they don't like water haha)
https://www.sau.com.au/forums/topic/438134-skylines-nt/#findComment-7194742
  • 1 month later...
  • 4 months later...
Guys, can one of you tell me a good place in Darwin to get my rims powder coated? Also where do you recommend to get a quality respray done?
Hey man! Ummm i used KC Customs for my front bar respray - They super good and have good quick turn around, not sure if they powder coat but they repair gutter rash and i'm sure can help you out! Defs full respray go to KC customs - Ask for Christian Butler and tell him Harrison with the R32 bar he painted sent you. What's your name? Do you come out to TC often? Would be keen to meet with ya if I haven't already met you!
https://www.sau.com.au/forums/topic/438134-skylines-nt/#findComment-7361835
  • 4 weeks later...
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
