Happy Laps - Queensland Raceway 22-03-14
Thanks SCR48, been registered for some years just not very active sorry......
Dyno day, Which One, Apparently there is 2........
not really planning on the Dyno Day, but will see what happens, looking forward to the Laps though :)
The tuned performance one is what a mate and I will be going to..
I thought i would have been the quickest out the at the happy laps if I went. But I will now pass that title over to you after my Downshift towelling you served up lol..
Also you've made it into my sig on SAU [Well half of your car anyway] after we all cruised out to DS together last month
OK sounds like a blast, might be up for the Dyno as well, just have to see how Saturday Commitments evolve LOL done a few things since last time mainly cosmetic but definately looking forward to the day...... Dan organising the cruise thing again?
Edited by 8MYCASH
I haven't heard from dan in a while but keen to get a good group out to DS next month if you're back from work at the time... I saw a pretty cool post on Facebook which involved a cosmetic change to your 35.. I definitely like the size and width....
waiting on weather forecast to know if I will be in a fishing tournament or bringing the legume to happy laps, just had it's engine mounts replaced so I'd kind of hoping for a cyclone so I can test out the smoothness... but don't tell my crew.
how late will payments be accepted?
I belive the latest is, don't pay into the bank account this week as there won't be enouhg time for payment to come throuhg, bring cash on the day?
Yup. Takes too long to process and then it becomes a shit fight.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
