$400 including bonnet pins but NOT washer jets. Front N1 type bonnet lip is built in.
Used, but is in good condition overall. File photo too big to upload.
Will sms photo
zero 4 one 8 78 zero 88 three
Pick up in Brisbane Bayside or can be delivered to most Brisbane suburbs for an extra $50.
Postage at buyers expense.
Edited by OVA 300
https://www.sau.com.au/forums/topic/438177-r33-gtr-frp-bonnet-in-qm1-white/
Give me a day or two guys. I'm smashed with work at the moment. I'll try and get some quotes, cheers Chris.
Josh, I see in your profile your cars are a gtst and R34 GTR. This bonnet is for a GTR 33.
e Go have a lot of options.
Cheapest is collecting from their depot.
After packing it up and me driving it the 80k round trip from my home to their depot in Brisbane you're looking at $150 ish, maybe a little more.
Trusting them not to break it is a concern.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
