Okay. I have a r33 4 door sedan.
My car has this problem, its very hard to explain so bare with me.
When the car is cold, it runs smooth and the car feels normal.
But when the car gets warm, it feels like it looses power.
When the car is cool, i can rev it and it will rev freely like it should.
But when it gets warm, ill put my foot on the accelerator slowly and coughs and farts a little bit and it will stop at about 2k rpm.. while my foot is still going down slowly the revs stay at 2k rpm, and then will SOMETIMES all of a sudden just rev through it OR if i get my foot to the ground, it will start revving between 1k and 2k rpm.. just back and forth.
So all this is usually when i get the temperature around 70 C. If it falls under 70 C, it will not do it.. so i know its heat related.
But when you get it warm, you can still get it past it, only if you put your foot straight to the ground and not slowly.
Now the ignitor gets quite hot..
When its warm, and im trying to rev it.. the lights are dimming and brightening like they are not getting enough power, like headlights, tail lights, dash lights, cluster, every light is dimming and brightening.
Ive checked the coilpacks, its surely not them.
It would not be the injectors, because they do not act different upon heat do they? and it floods when hot if i keep my foot down when its doing the revving between 1 and 2krpm.
It has a MAFless tune, so does not use a AFM.
Has anyone ever had this problem?
Its such a confusing thing to try and diagnose.
Its a wolf 3d one. The ecu has no errors.
It got worse and ran on 5 cylinders, and it sounded like a subaru, so we replaced the ignitor loom, ignitor, rechecked all the coilpacks and injectors AGAIN.
It fixed the subaru problem, but still when she gets warm it acts the way I described it in the post.
Only thing we have now is to replace the alternator, and check the coolant temperaure sensor..
Otherwise im out of ideas.
Have a look at all your earth connetions and clean them.
Resistance happens more so with heat, you mentioned things are dimming as it warms up.
Bit of sandpaper on all the eath leads should be a easy test/check.
In my case i ran a home made earth kit, basically some wires direct from the Negative to around the block, one of the ignitor models bolts, cleaned the big earth to the block...etc
Sometimes its something simple.....does not mean its not your ignitor though, or even your CAS, test with known working ones after the earth check.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
