Hey man, nah I doubt it, he said it's because of all the cootes trucks being defected or something, he told me that defect clearing for cars are only on Thursday's, I explained to him that I need the car for work and that it's my daily etc, so he stuck me in for Tuesday morning before the first truck comes in at 9 so I gotta be there at 8:30am, thanks.
Lol always a newb!
Yeah something i might look into as well! I kind of avoided it as i figured they can defect you with or without it, but in saying that its pointless to go so far and not at least try get it through haha
depends on what youve done.... ;)
and agreed, its absolute bullshit that there is no ultimate authority in nsw.
Does anyone know if they will be doing an emissions test.
depends on the paperwork.
is it a part, or full inspection?
theyay want to because of some of the mods youve been defected for, but if you say its all back to stock, they may not.
Bastards, called me today, said they overbooked for Thursday so now it has been re-booked for Tuesday, that means no Skyline over the weekend :'(, gahhh.
thats bullshit.
not your fault.
I would have rocked up and said I didnt get the message/someone else answered.
if your car fails, this weekend would have been a great time to fix the other problems.
So I just got back from the inspection and here's some feedback.
They cleared everything although I got a defect notice for blue slip because I need to get an Engineers Certificate for my Exhaust, Wheels and Intercooler, also my boot brake light wasn't working (the f**ker was working when I checked this morning), number plate obscured apparently by my rear view camera pfff, so now I'm on the hunt for a Engineers Certificate.
Theo Syriopoulos head of SYRIOPS Engineers delivered a talk alongside myself 3 months ago at Canterbury.
He does Engineering Certificates and assists to clear defects.
For starters, you'll need to get replacement tyres and a plumb-back, but you can call him on 0402651759 or 02-95336737 to get some expert advice.
He's stationed at 172 Belmore Rd North Riverwood
Called him today, he doesn't engineer what I need to be engineered.
Congratulations on the clearance... Did they actually use any tools in this inspection or is it just a quick look over?
You got another defect notice from passing your blue slip?
If they cleared your defects dude shouldnt you be fine?
What ever happened to that one modification law with no certificate we had? i.e. One air intake mod / one exhaust mod / wheels within legal parameters.
Yeah what f**king law, it's Straya mate no f**ken law here, they make up their laws how and when they please and if or if not they got laid the night before.
Back on topic, would a r33 cat bolt straight on to a r34 GTT, are they exactly the same, thanks.
The cats are slightly different length and also have an angled flange from memory! (Lol flange)
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
