13 row oil cooler and relocator kits - $200.00 delivered via express post. (Only 1 left)
Oil Cooler Features:
Materials: Made Of High Quality T-6061 Aluminum.
Colour:Blue
Rows:13
Overall Size: 18cm(H) x 5cm(D) x 30cm(W) - (Not including end brackets)
Inlet / Outlet Size: AN-10
Oil Filter Relocation Kit Features:
Materials:Made of High Quality Lightweight Aluminum with CNC Laser Cut
Colour:Blue
2 1/8” NPT Bung Covers
3/4"X16UNF or M20x1.5 Thread
Braided Hose Features:
Materials: Durable Braided Stainless Steel Line With Re-enforced "Earls" Fittings
Adapter/Hose End Degree: 90° & 0°
Hose A Length = 1.2 Meters
Hose B Length = 1.0 Meters
Hose C Length = 1.0 Meters
15 row oil cooler and relocator kits - $210.00 delivered via express post. (Only 5 in stock)
Colour:Blue
Rows:15
Overall Size: 21cm(H) x 5cm(D) x 30cm(W) - (Not including end brackets)
Colour:Blue
15%20row%20oil%20cooler%20and%20relocati
Fitment:
Universal Application for vehicles
No installation instructions included, professional installation recommended
Does not come with a Thermostat
SORRY NO PICK-UPS.
THIS ITEM IS IN STOCK IN AUSTRALIA AND DELIVERY IS USUALLY WITHIN 2-4 DAYS AFTER PAYMENT HAS CLEARED.
Please PM or contact us if you have any questions regarding these items.
Cheers,
www.performance-wise.com
www.performance-wise.net
www.yellowjacketscoilpacks.com
  • 2 months later...
Hi mate
Have you got both 13 and 15 rows in stock at this price currently?
Just want to confirm they will fit an R33 GTR? The sandwich plate that goes to the motor has an adapter for both UNF and Metric?
Thanks
Is this kit basically the below one from your website, including the o rings and and screw in fittings
cheers
CAOC01B-DELUXE 14 ROW OIL COOLER & RELOCATOR KIT
Both the 13 row and 15 row kits are currently in stock, here in Australia and will be sent via express post.
It will fit the R33 GTR and comes with both adaptors.
It is basically the same as the other kits and includes the O rings, screw in fittings and relocator mounting bracket.
:cheers:
Only 1x 13 row kit left. 15row kits price reduced again - only $210.00 delivered.
All coolers are in stock here in Australia. Clearance sale. Will not be getting any more at this price.
Be quick. :)
  • 6 months later...
Any direct fit for r34 gtt?
These kits will fit the R34 GTT. The adaptors included are a direct fit. Its just a matter of mounting the cooler in the desired location.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
