Hey peeps,
Selling my BC BR coilovers after using to pass defect (currently wound out as high as they can go)
The coilovers have no oil leaks, noises or issues that I have ever come across.
As you can see from the photos the bushes are in top notch as well.
They have been on the car for a little over a year or so now.
PRICE: $850 ONO
INCLUDED: 4 Coilovers & set of C spanners
POSTAGE: Buyers expense (But I will be traveling to Sydney for the next 2 weekends)
hLOCcCu.jpg?2
A1uGUwD.jpg?2
7tDFcg1.jpg?2
DYFzp7v.jpg?1
T7p0oqq.jpg?1
https://www.sau.com.au/forums/topic/439259-bc-br-coilovers-suit-r33-gtst/
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
