Hey Ya!
I have a set of Os Giken Cam gears for my R32 GTR, I am told these gears fit all skylines (Rb20, Rb25 & Rb26dett). Once I installed these gears on my GTR, put the belt on and clear cam cover and crank engine sensor, started the car my mechanic noticed a slight sound, found it comming from the crank angle sensor, he pulled the crank angle sensor off to find it had been rubbing against the gear, made a nice little mark on the Crank Angle Sensor aswell :)
Have we got the wrong gears for my car??? or whats going on??? any ideas?
I rang the place I got them from in australia, and they tell me that OS Giken use the same cam gear for both sides (In & Ex) so that the same gear gets used for both sides but 2 of them. They tell me they have never fitted them to a gtr before and dont seem to have a 100% reason why they would be rubbing against the crank angle sensor.
If anyone out there can help me ASAP I would more then greatfull as I want my car back on the road bad :D
Let me know what you think please
Thanks
CHASP
You shouldn't have a problem with the cam gears.
I'd put the factory cam cover back on (leave the adjustable cam gears on) and see if it still does it.
The only reason they should rub is if the clearances are different, and the only thing between the CAS and the cam gear is the cover.
I have seen another set of adjustable cam gears rub against the CAS, althouth these ones were stock cam gears modified to be adjustable, and the nuts/bolts that were used on them to make them adjustable was where it was rubbing against the CAS.
To overcome the rubbing they put spacers (washers) under each of the 3 bolts that hold the CAS to the cover/gear assembly. It gave enough clearance for it to stop rubbing.
I hope that helps.
J
did u use the original rubber seal that is fitted to the cover behind the cas, if not u need to remove the small steel spacers fitted into the rubber, it has to have these spacers otherwise it will rub on the cam gears, if u dont have u can use washers, u need spacers about 5mm long.
:werd:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
