Tuned Performance Dyno Day - 22/03
Nah Cara would rather do some more retrim. And the pink plenum is embarassing lol
Retrimming complex curved panels is f**king shit btw. Swore id pay someone to do it next time, but here we go again.
Issues with my timing I think.. Ah well something to work on. Looks like a good setup in there and there was a strong showing from the SAU members. I felt out of place without a club shirt
good result
I was expecting less, so ill call it a win
And that's a fair amount for me still being on p's but I still have more room to play with yet :D
And nick :P we thought why not we will see and then we can go up from there
I have a few bits laying around so we will throw them on and see what we can get from it :)
Had a great day guys! Thank you so much for all the support. I couldn't have done it without you all Anyone chasing any work or tuning I'll be doing a limited time discounted labour rate. Will announce it in the next few days. Also as a sau qld member you will receive a 15% discount in my shop.
Cheers again guys and girls
  • Like 1
Wish i was there to watch the shenanigans with tehF6 pumping out big numbers. I believe traction was a major issue even with a few people sitting in the back. I read of FB this car normally makes around 800hp mark
  • Like 1
I have a few bits laying around so we will sell it and buy her a real manual, turbo, series 2 and go from there :)
FYP :P
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
