Hey all, I'm selling my beloved R34 GTT, and with a new car on the way, the sooner this sells, the better.
Car was imported in 2009 and I have been the only owner in Australia. I have all the paperwork for everything, including mods.
Only reason for sale is the fact that I only have one car park space in my apartment, so unfortunately I can't keep both.
Car is currently located in Albury Wodonga with SA plates, I am happy to get a transfer to NSW rego or drive to SA for inspection if the buyer is serious.
Car is super-clean inside and out, decals have been shaven off and car has partially been put back to stock as I recently got off defect in SA.
Serviced every 5-7000km with Penrite oil.
Plates "RB25DET" are also for sale, you can buy them seperately or with the car. Not sure about the price, make me an offer!
Here are the mods:
-Blitz Pod Filter
-Z32 AFM
-AM Performance full turboback exhaust with titanium tips (looks and sounds fantastic)
-R34 GTR intercooler
-Oil cooler with Greddy thermostat (keeps the temps way down low in any weather)
-Koyorad radiator, 55mm
-Custom intercooler piping
-Plumbed-back Blow off valve (Greddy I believe)
-725cc Bosch injectors
-Bosch 040 fuel pump
-NPC Ceramic Clutch (single plate)
-New, lightened flywheel
-Nisstune Piggyback ECU
-JIC FLT FAS coilovers
-Cusco rear camber arms
-Kazama front castor rods
-Diff shimmed by 0.8 or 1
-New head unit
-Internal lights for door, etc replaced with bright LED lights
-Genuine Nismo LED tail lights
Not installed:
-Garrett 3071 GTX turbo, just needs to be installed, I have most, if not all, the parts to install it.
The bad:
-Air Conditioning seals broken and gas empty, should be an easy fix and I can do this if needed be
-Car is tuned for the bigger Garrett turbo, so I recommend a fresh tune. Still runs well albeit a bit rich.
Car has 141,000km on the clock, mostly from highway driving between Sydney, Albury, Melbourne and Adelaide.
Price:
$16,000 without LED lights and turbo, $18,000 with everything
I can take off $1000 for the LED lights and another $1000 for the turbo if you do not want these, I have buyers for these already but they complete the car.
Contact: 0412 741 434 or [email protected]
Engine bay pics to come shortly.
Thanks for viewing :)
https://www.sau.com.au/forums/topic/440086-sansw-clean-1998-r34-gtt-from-16000/
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
