Hey all,
I am looking to buy a Plenum for a track GTST R33.
Have read through pages and pages of info.
Im leaning towards a plazmaman or a Greddy as im after useable torque.
But what about a R33 GTR Plenum? What is needed to make it fit? And is it worth doing it over a plazmaman?
Looking at around the 375 to 400kw mark, what size throttle body to go along with the plazmaman would i need?
Any other info would be great
https://www.sau.com.au/forums/topic/440108-plazmaman-plenum-vs-gtr-plenum/
I run 391kw and the 66mm seems to be holding up alright, if its a track car you will be at WOT more than you would on the street so possibly wont hurt to go bigger!
GTR plenum requires more effort to fit compared to the simple bolt on applications as you have multiple TBs etc i assume.
^ GT-R plenum would be worse IMHO because you need to run one of those fugly hacked up spacer plates and that would affect airflow and also the injector spray would be offset.
Of course, it has been tried & tested.. but for 370~400kW why not stick to the stock plenum, but if you have cash to spend might as well get a Plazmaman plenum :)
Thanks guys.
Im after the plenum to clean up the engine bay to.
Also while people are reading, removing the air polution stuff.. is it as simple as disconecting and plugging the holes? wont effect anything?
Thanks guys.
Cleaning up the engine bay is one thing but remember if you are doing these kind of plenums (well in regards to the Plazmaman) relocate your oil filter and do an oil cooler setup while its apart as its a bitch to get to the filter once its all together! Its even a mission on mine just to check the oil level on the dipstick lol
you mean the charcoal canister? yeah go for gold!
while you're at it, might as well setup an atmo catch can
(it's a dedicated track car that will never see the streets right?)
Yer that little canister with a couple rubber n hard lines running to it. excellent. yer definatly a track only. never ever see the streets!
hahah thanks for that advice! one of those things you dont think of till its done and then swear and yell about it!
Yep, hence why you learn from others mistakes lol :D
  • Like 1
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
