When you arrive at your first meet, make sure you segregate yourself by race and religious belief, the Mexican will approach you, compliment your vehicle and ask you what you are running under there. At this point don’t be too concerned he isn’t gonna hit you for slips as he is going legit and trying to get on the NIRA circuit. So reply with some sporty banter and embrace him with a mafia spec hug – kiss on the cheek is probs too soon ONLY ON THIS OCCASION .
During the drag race, don’t hit the 100 shot of nos too early, you don’t want the welds to blow on the intake or the floor to fall out too early. You want the floor to drop just as you cross the finish line so if you happen to be racing a red RX7 he can’t activate his nos at this stage.
If police happen to raid the meet, make sure you pick up the owner of the red RX7 if you see him on the street, this is your way into SAU. You will be invited to a post meet party to play some GT2 and some coronas. Don’t bang his sister just yet.
Exchange snap chat names with her, screen shot nudes and post to SAU. As the grand wizard is an RX7 owner he won’t see nudes of his sister on SAU.
If you are going to take her out one night, make sure it’s a Cuban restaurant called cha cha cha.
At this point in time, I am hoping you are not a cop, as we run a great racket here at SAU which helps us pay for the shit under the bonnet of all these cars. I will let you in on a secret its cheap chinese DVD players worth about $20 a pop, hence why everything uses china turbos and knock off rota wheels as gee the money is good but not legit parts good.
This should give you a good feel of the place and enjoy your stay.
  • Like 2
https://www.sau.com.au/forums/topic/440125-new-car/#findComment-7220826
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
