Car now priced at 26,500ono
BR,
JH
Hey,
NISSAN SKYLINE 1995 R33 GTS-t ( 10 Months Rego )
Engine:
           RB25DET – BRAND NEW FROM EMPTY CRACK TESTED BLOCK UPWARDS.
           Wiesco Forged Pistons And Rings
           Race Doubled Up Slide Pins, Instead of circlips.
           Bored out 20Th
           New Bearings big ends, little ends
           All new seals rear main/complete VRS KIT.
           Valve Stem Seals
           Head totally reconditioned
           Done 630Kms Since Complete Rebuild
           All receipts and pictures of rebuild for proof to purchaser
XTR GT35/40 Turbo
           Teil 48ml Wastegate w/ Screamer Pipe
           Dyno Dave Tuned Length Exhaust Manifold – Work of art.
           Custom Made Plenum 80ml Throttle Body
           Trust Front Mount Intercooler
           Turbo XS Bleed Controller
           XTR Turbo Blanket
           EMS STINGER 800
           Nismo 770cc Injectors
           Bosch Motorsports Fuel Pump
           NISMO Mechanical 9Plate DIFF (none of this viscous crap)
           5Puk Clutch And Pressure Plate 500HP
           HKS Air Pod
           Silicon Hoses everywhere the silicon hose from the inlet to the Air pod is $500 alone.
           Turbosmart Blow Off Valve
Exterior:
           All new pineapples and suspension
18Inch DTM wheels
           3 ¼ inch exhaust  with trust muffler
           Remote Central Locking
           Full Alarm / Immobiliser
Interior:
           Sony CD Player
           Odyessy Batter
New motor has not been dynoed but old motor produced 323rwkw with the same setup reason for rebuild was old motor was tired as it was standard it pushed a bit of oil past the breathers when you got into it. The 323rwkw was on 18psi with the same gear on the worn out motor. Some C16 25psi of boost I would like to think around the 390 – 400rwkw would be achievable being one of the most powerful R33’s on the street everything has a lot more to go nothing is at its limit so anybody looking to further an insane project then this is it. All work by registered mechanics.
Everything Is brand new I regret the need to sell especially just after a complete rebuild the car feels great.
Car is immaculate inside and out
Selling due to the purchase of a house $29,800 ONO
           Please email me at [email protected]
[email protected]
Im neg need to sell.
BR
would it be possible to obtain a dyno graph of kw output... dont take it the wrong way i'm interested in how the drivability is with such a big turbo....do u recieve any boost on the street? if so what rpm does it start screaming.....cheers!
It would be if I had it was from over a year ago and Ive lost it, IF it gets done again soon which it might Ill put it online for everyone.
Boost comes on around 3000rpm and screams about 4,500 - 5000.
When it hits though any gear other then 1st your doing well over the speed limit in about 3 seconds. any one who thinks thats bullshit, can eat my d8ck.
JH
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
