It depends on a few things.
I doubt anyone has done it before.
First thing find out if you have a tiptrinic box - re4r01b if yours has an re4r01a it wont be easy.
says it on id plate in engine bay
I'm pretty sure that you would be the first to try it.
If you can get the shifter cheap give it a go.
Actually there is a plug that goes into the shifter for the tiptronic, check that's there near your current shifter to plug into.
$100 on eBay
I will see if I got extra plug not plugged into anything under there.
If I got the box u would think so.
I will update see how it goes for anyone wanting to do it in future.
Thanks mate
I've got the correct s2 box but wrong loom so prob convert to turbo and manual. As it is a gt4 (awd) thinking stock neo turbo and manual. Or saving up extra for rb26 and making a 4 door gtr ha ha
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
