Harro,
Item 1: NPC Carbotic Clutch Disc
Price: $300
Comments:
  • Thought my clutch died, turns out my clutch fork was fractured & my bearing carrier was the incorrect
  • Scott from Western Clutch measured it and said it's about 0.04mm worn only, near new
  • Disc is under 2 years old, has had about under 14000 km street driving and 3x track days, car makes under 200kW
Reason for Sale: Downgrade to a lighter disc that's more drivable for the street
Item 2: Toshi Remapped R33 Series 2 ECU
Price: $300
Comments:
  • Difference is day and night, others will understand
  • AFRs super safe, sits about 11.7~11.8 all the way at 0.9bar - has been taken to the track many times
  • Tuned for full exhaust, front mount, healthy fuel pump, and boost at 0.9 bar, ~13psi
  • Please check your base timing, set it at exactly 15 on idle with the TPS disconnected
  • Will install and check your base timing for free if you're local
Reason for Sale: New turbo & ECU
Item 3: Stock R33 Series II GTS-t Manual Radiator
Price: $50
Comments:
  • Decent condition
  • Doesn't appear clogged or anything
Reason for Sale: hast tag becauseracecar lol
Item 4: Stock R33 Series II Front and Rear anti roll bars / sway bars with bushing & brackets
Price: $80
Comments:
  • Decent condition
  • No cracked bushing
Link to other stuff for sale too:
http://www.skylinesaustralia.com/forums/topic/433062-fs-syd-r33-gts-t-part-brake-pads-subframe-collars-wheels-gauge-holder-misc/page-2
Contacts: PM or Reply Here
As always, will trade for beer and/or alcohol too :woot::woot:
Item 5: Stock R33 Series II Stock Turbo
Price: $250
Comments:
  • Comes with elbow
  • Has minimal shaft play
  • No funny oil leaks
  • Exhaust wheel has not fallen off yet LOL
Reason for Sale: hash tag becauseracecar lol
buy my shit, will trade some stuff for:
  • 2x NEW Nitto NT-05 in 255/40/17
  • 6x 1000cc OR 1200cc sidefeed injectors
What has been done to the ECU? Was it socketed for a programmable EEPROM or Nistuned?
hey mate!
Socketed ECU with a reprogrammed ROM
Don't think anyone has installed the new Type 6 Nistune for R33 ECUs yet, I know a few of the Stagea boys have though.
Yeah I have done up a Z32 ECU with a Nistune board... but I thought a quick ECU swap for more boost would be a nice thing. I don't have the cash for a tune (and possibly never will) and i'm maxing out the AFM at 11psi. =-/
MMMMM will the clutch plate work in a jim berry pressure plate
Dooo it!!!!!!!!
Also ECU sold :)
Can't see why not? After all NPC pressure plates are modified Exedy covers :)
Dooo it!!!!!!!!
Also ECU sold :)
Dammit...snooze you lose :domokun: was about to PM you :( Mayb I should just keep saving and go the way of a PowerFC.. Goodluck with selling rest of your goodies
buy my adaptronic ECU and it will come with a free modded car for $12k :)
I like breasts
Stock Turbo & Dump $250
Clutch $200
Stock ABS Diff $250
Stock Rad $20
New Braided Oil Feed $50
Stock Front and Rear Sways $40
Stock S2 AFM $50
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
