Ok, counting just who has posted here we have 32 people and 19 cars. We will probably have a few extras from the FB event that haven't posted here as well, like Mike in his R35.
Damn I got at least a 3 hour drive just to get to the goldy haha, country town life :(
should make the treck to the GC tomorrow and drive with me to Mt Tamborine the next morning
Have fun on the cruise tomorrow guys, wish I could bring the A-Bomb out but well yer, keep it safe and have a ball :)
(82 days and she'll be back out keeping all you RBs honest)
  • Like 2
It's on Sunday! You saving up for a Harrop kit now?
Is it too late to organise a bikie rally in Brisbane for sunday so the cops disappear from the streets altogether like they did on Australia day?
Possibly, you could get Zeke onto it tho.
