hi guys my dad has just bought a 180sx. it has a bottom end knock and we are going to rebuild it, nothing crazy just a reliable motor. I was wondering what we should do, should we buy a new aftermarket bottom end or just replace it with a second hand crank rods and pistons and how much a new bottom end would cost and good brands to get them from thanks.
https://www.sau.com.au/forums/topic/441372-180sx-bottom-end-rebuild/
Yeah it's a sr20det I got a price from KYP for another sr20 they want 1600 for a running one so with that is it still cheaper to buy another one or just rebuilt the bottom end of this one I have found some rebuild kits for around 700 to 1000 so I'm leaning to the rebuild idea
Pull the engine out, mount to a stand and strip the bottom end to assess damage. You might find that it doesn't need a new crank or even pistons, depending on the amount of wear / damage. I've re-bearinged engines with a bottom end knock, and as long as you get to it before the bearing's spun or worn through, the crank might not even have a mark on it.
You have to pull the engine anyway, so why not strip it and assess its condition before making a decision? Best case will be a full gasket set, rings and bearings, (plus the associated cleaning, cylinder hone etc) and timing chain / guides / tensioner etc.
Worth a shot, and a good learning experience.
...Worth a shot, and a good learning experience.
Agree. Rebuild and learn something :) I rebuilt a hemi 6 in two days with no prior engine building experience.. just made sure that I had all the parts ready to go and dis a lot of reading.. a lot of reading. Also YouTube is also a very good friend. Youll also find you'll enjoy the satisfaction of saying you did it all yourself :D it cost the same as buying a crate engine but hey, what life experience worth?
  • 4 weeks later...
You'll find that the conrod bearings may be shagged. So a crank machining may be in order. If you dont want to go full house build just hone the bores and re ring the pistons as well as new bottom end bearings. Get yourself a new gasket set with a metal head gasket.
Throw rocker arm stoppers because... well why not seeing as its already apart.
That shouldn't fail your little brother for the time he owns it. Unless he drives it like its stolen. Then you may run into a future problem.
Look for the same things as you would have on the reds.. all engines work on the same principle. i would make a note of replacing everything perishable with new stuff. Crank machining isnt always necessary but its easier to do now while its all apart than later on.. and who likes doing things twice? Do it right, do it once :D
Edited by c34Florry
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
