Previously on my S15 which produced 477.3 rw kws from a 2 litre. Never used on the road or drag, just dyno and shows. Should produce well over 500kw on a 6 cylinder (RB/JZ motors) In mint condition - almost brand new, lucky to have 1000km on it. NOTE: non roller bearing - RACING VERSION from HKS. The last model before the roller bearing version was brought out.
All i can say is OMG!!!
is it just the turbo itself or the whole kit?
CONAN, YOU OBVIOUSLY DONT KNOW WHAT A HKS T51R IS WORTH. A FULL T51R KIT IS WORTH WELL OVER 9K AUD NEW. JUST THE TURBO BUDDY, NO MANIFOLD OR GATE. LOOK AT DEANS POST "T51R SPL BB GTR KIT", HE'S SELLING FOR 6500 ONO 2nd hand.
i have a fmic, airfilter, bov, turboback zorst, and bleed valve,
what else do i need to make this turbo work with my system?
i have a rb25det
say i want it to spool quick and hold boost for long, without killing me engine etc.
help would be great
CONAN: The HKS T51R really isnt the right turbo to go with your cat back exhaust and air filter. Look at the power rating on this turbo, as per BMT's posts above and it should be clear to you that a full engine build would be required on an RB25 to have any hope of sustaining the power that this turbo can produce.
i have a rb25det
help would be great
:D :D :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Remnis, do you have the dyno sheet that your monster produced?
Yeah, what Nick said... this turbo aint for the faint hearted :headspin:
Wouldn't mind seeing one of the more experienced members grab this a get a new project goin :aroused:
hay man i was just wondering i got a s15 getting pistons and rods dun.. got cam gears and cam shafts and other nick nacks.. what sort of lag would i get?
and if you had to sell it would you sell it with the manifold and front/dump pip and wastegate with it ?
If you wanted this T51R for your S15 i can sell the turbo and manifold only - dump pipe and front pipe should bolt straight on to your standard one, and the waste gate you will have to source yourself. Lag? mmmm Honestly you will have a hell of a time keeping it on the road. As for lag, with a non stroked sr20 i pushed 477 rw kw @ 1.8 bar at around 8300rpm. This turbo, depending on how big your cams are, will start producing boost at around 4800-5200rpm depending on how good your tuner is. Buy it buy it, i wanna see it street driven daayyym smoke a set of 285s in one burn out.
  • 1 month later...
please e mail me re this turbo [email protected]
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
