Hey Guys,
Sorry if a similar topic has been covered, but just thought I would start a new thread to add more specifics etc.
I have a series 2 R33 GTST which is having an annoying idle issue. I replaced some snapped exhaust manifold bolts and there is still one snapped but meh that can wait, it isn't the cause I am pretty sure as when three were snapped it didn't idle as crap.
When idling it sounds all over the place like up and down whirring like if u imagine a police siren whirring but it's the sound of idle lol. It on occasion will also feel like it has just dropped out like it's on 5 cylinders for a split second then comes straight back. The taco doesn't seem to hunt though. It occasionally also has a weird cold start where it starts really quiet then like two seconds later bursts to life but usually starts nicely. A bit fuel smelly lately too. Anyway here is what I have checked (not much yet) and then what I am suspecting. Oh and also when I tried to adjust idle with idle return screw when I pulled the TPS the car stayed on as it should but one time when I pulled it the car died? Oh and the car gave me a code for coolant temp sensor and i cleaned it up a bit and put it back and the code went away? Sorry for the essay!
What I have checked:
Cleaned AFM
Cleaned AAC assembly- noticed an o-ring is missing and a gasket?!
Checked all hoses for vac leaks, pretty sure they ok
Checked all hose clamps etc tight through the air intake
Cleaned cold start valve
Pulled each coil pack whilst car was running- does this just check your cylinders or pretty much tells u whether coil pack is rooted or not?
What I think could be wrong:
Still some annoying vacuum leak somewhere
Throttle position sensor
Dirty throttle body
The missing o-ring & gasket on AAC/IACV assembly
AFM still- how else can I check? Resistance?
Still the water temp sensor even though code disappeared
Coil pack
Problem with the waste gate?? How can I check if it is stuck??
Anyway thats enough for now, it's doing my head in so any advice would be great!
Thanks heaps
Em
You can rule out the AFM by unplugging it while on idle and if it stalls then its good and if its still idling then its no good.
Running on 5 cylinders could be two things from my experience,either one of the coil packs is playing up or dirty/blocked injector.
If it starts to run on 5 cylinders for longer, try unplugging each coil pack to see which one makes a difference in the sound and if one of them does not change in sound or note then u found the coil pack that might be faulty but can also lead not to be coil pack but injector which you can do by unplugging each injector plug to see if it does the same thing to changing the sound.
i would run a bottle of injector cleaner through your car, i had a surging problem and it also made the idle a bit erratic and injector cleaner fixed it on mine, injector cleaner is cheap and its worth a try
Thanks guys! I did the power test and all good and was actually going to run some good quality injector cleaner through maybe moly stuff in the metal can.
It's becoming so frustrating! The coolant sensor code isn't showing now but doesn't mean it's still not rooted I'm just going to replace it and see what happens. Sucks cos the car drives so nicely and I am spending half my life trying to fix this ass hole idle! Could it have anything to do with cam position sensor?? I'm starting to think cos the aac/Iavc was missing gasket and o ring then that could be a main cause? My pcv is rooted also :(
I'm pretty sure it's not the exhaust gasket and missing bolt because its not the same noise etc and it wasnt this bad with extra bolts missing. When I have the money ill take it somewhere but I know I can do it myself but I need to pin point the issue first
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
