Gtr r32 wheels in very good condition with brand new rubber
Asking price $800
Bbs lm 17inch (gold in colour) with brand new rubber fronts have smaller dish then the rear but still same tyres size all round 235/45 17
Asking price $1500
Gtr n1 front bar brand new in the box
Asking price $350
Rb26 Center rocket cover in gold no badge
Asking price $200
Gtr r34 cams that came with my brand new nur crate motor I bought brand new
Asking price $200
Greddy pipe for single turbo
Asking price $150
Gtr r32 stock exhaust and dump to pass emissions
Asking price $400
Gtr r32 radiator fan with and fan assy
Asking price $200
If you next me I can send you pics straight away on 0426 143 856post-100658-0-77670200-1398035170_thumb.jpg
https://www.sau.com.au/forums/topic/442125-lots-of-gtr-parts-wheels-etc/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
