Hey guys got a few things to sell.
Injectors and rail $200 + postage
Turbos $400 + post
Airbox with k&n filter 200 + post
Afm's $100 + post
Manifolds and shields $100 + post
Twin turbo pipe $20 + post
Gaskets $20 + post
Assorted piping $5 + post or free if you pick it up.
Parts are located in Townsville and are plus postage if required
https://www.sau.com.au/forums/topic/442193-gtr-parts/
Air box sold, twin turbo pipe and pipework sold, gaskets sold. Everything else for sale still.
Also for sale
proflow fuel rail and Siemens 875cc injectors, injectors just fully serviced and fuel rail has about 1000kms on it. $500
https://www.sau.com.au/forums/topic/442193-gtr-parts/#findComment-7265307
Turbos $400 + post
Afm's $100 + post
cast turbo inlets $50
proflow fuel rail and Siemens 875cc injectors, injectors just fully serviced and fuel rail has about 1000kms on it suit rb26. $450
https://www.sau.com.au/forums/topic/442193-gtr-parts/#findComment-7270766
Injectors and rail $200 + postage. SOLD
Turbos $400 + post
Afm's $100 + post
https://www.sau.com.au/forums/topic/442193-gtr-parts/#findComment-7274087
Turbos $350 + post
Afm's $80 + post
Manifolds and shields $90 + post
cast turbo inlets $50 + post
proflow fuel rail and Siemens 875cc injectors, injectors just fully serviced and fuel rail has about 1000kms on it suit rb26. $450 + post
prices are neg on everything except the proflow rail and injectors
https://www.sau.com.au/forums/topic/442193-gtr-parts/#findComment-7276561
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
