I have a series 1. Just wondering if anyone has any experience with changing the engine to a Neo with loom and ecu etc so it can be tuned without all of the piggy backs. Thanks. Justin
Not so simple as the Neo auto control is quite different. Much easier to convert to manual then you can use any ecu you like ( as I have done).
Or get a Greddy E-Manage - that's just one piggy back.
Well I have the manual box etc all ready to go. Doing that in the next couple of months. My main worry is the fuel economy. Im getting 17/100 have changed o2 with no difference. So after the manual is in which ecu did you change to?
Its all in my sig at the bottom of the page - Link G4
I changed my s1 to a neo and nistune, step 1 change to manual saves about 1/2 off the loom transfer, but still it's a bitch of a job loom has to be spliced to operate between s1 and s2 , as aircon, abs, altessa all have inputs and out puts running through Ecu , so it's quite a big wiring job even with out the auto and if you had to pay an elecy who knows what he is doing would charge over 1k ,
If your only reason for doing this is fuel economy don't bother, not going to make that much diffrence , . If not piggy back an emu or the likes to a s1, the only reason I changed to neo was it was the start for some moderate decent power, with a stronger engine and it was a step to where I heading now/next with my build I also wanted to run and tune with nistune much more economically viable for me ;) . You can just put a neo engine in swap the cas wires around and it will work but you will still have to piggy back onto original Ecu.this way you can still leave manual. I used and tuned my old e manage ultimate on my old auto s1 set up made 240kw on pump98 with an auto fuel pig though .
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
