Hey guys for sale is my GENUINE Trust/Greddy TD06SH 25G 8cm (responsive). This comes with the whole kit including the
Greddy turbo
Greddy exhaust manifold
Greddy external waste gate
Greddy dump pipe
Greddy exhaust housing heat shield
4inch intake
All the braided lines and fittings
All gaskets and bolts
This is an outstanding setup, all made to work together for best performance. The compressor housing is professionally sprayed black for stealth and a neat look.
Its still fitted to the car so u can come test it before i get it removed. Its seriously an awesome turbo kit for the rb engines.
For fitting you can just unbolt the manifold from the head and unbolt the dump form the rest of the exhaust and drop it in your engine. CANT get more bolt on that this.
Its don't very little work. Was installed march 2013 when the whole car got built and only had 5-7000km on the motor on street, was more of a show car.
Made a very strong 320rwkw on 18psi. Easy 360+ on e85.. Not for the faint hearted i should say
Only reason for sale is that I'm going a different direction with the whole car and motor.
Asking $3500 (brand new retails close to 7k) … grab a bargain
contact Andrew on 0450232121
Melbourne but can't post very cheap
Also have a matching intercooler and piping, and also a 3.5 inch HKS exhaust for sale too if your interested. All already on the car and can be tested.. Get in before i remove them :)
Hey mate I take it this is for an RB26dett cylinder head?
I'm currently running a rb30dett setup in an r32 GTR and looking to go to single turbo.
Currently running 22psi with twin HKS 2530's.
couple questions:
1) will this fit r32 GTR?
2) can you post a pic of the turbo installed in the engine bay - want to get an idea of clearances because my cylinder head is sitting 38mm higher. Ideally, can you post a pic of the height of the turbo/plumbing relative to the height of the rocker covers? (ie like the photo you have but from a lower angle, it's hard to tell how high the turbo sits)
3) does this include some kind of dump/front pipe setup to connect up to the stock cat converter position?
4) what is the diametre of the outlet on the turbo? Does it have some way to connect to the stock intercooler setup?
Edited by dorifticon
  • 9 months later...
  • 1 year later...
Back up for sale again.
Kit now includes:
Greddy turbo (8cm rear housing)
Turbosmart Hypergate45mm external waste gate
Greddy dump pipe
Now fitted to my r34 gtt and still in the car so if you are early you can get a test drive. Making 322rwkw on 18psi on BP98
Reason for sale is going bigger turbo.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
