Hi all.
I have been searching through forum for m35 stageas for sale
what I have found are quite a few that have been bumped and no responses for a few months. but still no mention of weather they have been sold.
is it that they still have it in mind that they want to sell but not willing to put up with all the tyre kickers harassing them like what happened to me when I sold my last car I had to basically give it away just to get it out of driveway.
what I am after is all those Guys/Gals on this forum who have it in their mind to sell their m35 but don't want to advertise because of above reasons.
Carsales and gumtree just dont do it for me too many dealers cars not many private and none with modifications.
two in particular are
http://www.skylinesaustralia.com/forums/topic/432605-eoi-om350/
http://www.skylinesaustralia.com/forums/topic/437415-m35-stagea-the-ultimate-daily-237kw-wheels/
https://www.sau.com.au/forums/topic/442775-whats-for-sale/
I'm not sure on weather or not they are still available, but I have seen both And they are awesome.
Plus they both tick every box as far as mods go. You would easily spend 10-15k on top of buying your car to build one to this level.
https://www.sau.com.au/forums/topic/442775-whats-for-sale/#findComment-7275415
It's a beautiful car in the flesh, and the Spoolin12, the original owner is a professional motoring photographer.
Bang for buck; this car is possibly one of the comprehensive packages anyone has done.
The car went for an absolute song, compared to the money invested; is the new owner on the forum at all?
that's that one accounted for
https://www.sau.com.au/forums/topic/442775-whats-for-sale/#findComment-7275792
I'm now hoping to find one tastefully modified.
with work constraints I would not have time to modify also I don't think it would be easy to find anyone in southern Tasmania willing to touch such a car
being only one garage I can think of that does Japanese cars ( GT Garage )
https://www.sau.com.au/forums/topic/442775-whats-for-sale/#findComment-7275796
  • 1 year later...
well a year has gone by and still no stagea partly because not many if any are available for sale here in tasmania so i bought a gu patrol to move the family around in jumped on gumtree tonight and well i think im selling the patrol
http://www.gumtree.com.au/s-ad/legana/cars-vans-utes/01-nissan-stagea-250t-rs-four/1082643814
https://www.sau.com.au/forums/topic/442775-whats-for-sale/#findComment-7560647
  • 4 months later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
