heys guys selling a barely used walbro 450lph e85 fuel pump replaced with a brand new one thought it was a problem but wasnt $100
malpassi fuel regs x2 1 with gauge $70 each
r33 series 2 bonnet silver mint condition $120
r33 front guards silver mint condition $50 the pair
c34 stagea series 1 headlights $70
s15 stock exhaust system cat back $120
autometer boost gauge 30psi in a black cup 60mm $70
r33 gtst s2 manual rear subframe complete with diff brakes hicas lock bar $250
r33 gtst boot trim $50
might have other bits n pieces laying around
all items are located in east side melbourne
0431135414
https://www.sau.com.au/forums/topic/443099-walbro-fuel-pump-fuel-reg-bits/
  • 3 weeks later...
What a rip off buyers beware
I purchased this pump off him about 4 weeks and still haven't received it
He said might have been lost by auspost and got it returned and will post it back ASAP
A week later no pump and stopped replying to my messages as I wanted to get a tracking no this time round
His been online and I've asked him for tracking 3 times no reply so clearly he has ripped me off and didn't intend on posting it in the first place
So just beware not to waste you money and purchasing off this guy
I'm just going to purchase a new one save headaches and waste of time not worried about the money $90 down the drain but I waited almost a month now
Biggest scammer ever
since this comment things have been worked out. was returned to me as the post office couldnt deliver either due to my poor hand writing or no one at address,
since getting the fuel pump back i was more then happy to send again this time id have my mrs fill out the postage details but he has then said he doesnt care if i send it or not
either way i will be sending it again regardless of what he said as he has paid for it plan and simple.
not trying to scam anyone have sold alot of items on here i always try my hardest to make sure the items i send are safe and secure clearly i cant control all of aus post
^ could happen to anyone mate, thus these days I always print & stick my labels on :)
that way those numpties at AusPost can't screw it up!
I've had soo many dramas with aus post. I started writing everything in capital red letters on white paper. Seems to have worked ;)
What a big scammer and liar
Glad I purchased a new one on Monday received it wed
If he didn't intend on posting it why bother posting on here saying that you are going to post it and get your wife to do it full of shit
I know I posted I wasn't bothered about it but why would you lie about it to make yourself look innocent
It was Monday he said he will post it now it's Friday nothing and I'll already received my new one which I ordered the same day
Buyers beware that's all I'm going to say
Happy days got my new pump and hope no one has to deal with this scum
Doesn't take that long to receive stuff from Vic
I've gotten a spoiler from as and was here in 2 days std post
Not a week or 1 month
I don't care as I already got a replacement but am warning others and don't want other people to get ripped off
no one has had a problem with me before and ive sent a lot of items all around aus mate, been a member for a long time, think u need to tae ur adhd meds and calm the f**k down, as other members have commented it can happen to anyone
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
