Heya all. I'm a current Skyline owner and due to being a father and needing some more space I've decided to look at an M35 Stagea. I live in NZ so I don't believe the import restriction on 250s applies, but it's something I'm confirming. I plan to bring in a car myself so I can pretty much put together a shopping list of what I want, but I do need to buy it sight-unseen.
How much of a difference is there in petrol consumption between a 250RX and a 350RX4? I also wasn't sure if it would be worth considering a non-4WD 350, given the extra power. I haven't been able to find any petrol consumption stats about the M35's.
Are any M35's available with cruise control? It'd be a "nice to have" thing.
Any particular gotchas I should be on the look out for?
Thanks in advance!
NZ import facts
The 2.5L can no longer be imported into New Zealand because of the emission code is too old on the engine.
Only 3.5L Stageas can enter the country. They carry the. CBA emission code which allows it to be complied.
Only Japanese cars with the 3 digit emission code before the VIN are allowed in.
You can still purchase second hand stagea 2.5L that came into the country before this emission code law change.
Stageas are gas hungry, the 3.5L is 210Kw, that's more than most modern V8 :)
If you want the power, you pay for it at 14L for 100km. That's about $35 nzd for 100km travel around town.
You buy these cars if your into massive amounts of grunt, not if you are on a gas budget.
Thanks in advance!
Also,
I am happy to help.
My car just got complied today.
I bought it from Japanese car auctions.
I highly recommend Provide Cars Japan, Eugene was my agent, he's awesome. Very helpful.
I can give you all the current information on what you need, how it's done, what it costs.
It's very addictive, I spent 2 weeks fighting for cars until I finally got one I wanted and at less than what I was expecting to pay.
Agents won't rip you off, they been in business for 14 years and are incredibly professional all the way to getting your car on the ship for you delivered to your doorstep.
Even got a radiation reading... So you know it won't glow at night :)
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
